Driveshaft Safety Loop... - TCCoA Forums
post #1 of 11 (permalink) Old 08-29-2007, 01:03 AM Thread Starter
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
Ok guys,
For my TBird to pass Tech and be able to make a 1/4 mile, I need a driveshaft safety loop. I know some of you are running one. What have you got?
TGJ is offline
post #2 of 11 (permalink) Old 08-29-2007, 09:12 AM
A couple factory, oem safety loops are on mine. Yours had 'em when it was new. Look at it.
icantdrive55 is offline
post #3 of 11 (permalink) Old 08-29-2007, 01:53 PM
Chapter Director Coordinator
jamesD's Avatar
the OEMs don't count to most of the techs
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #4 of 11 (permalink) Old 08-29-2007, 05:42 PM Thread Starter
TGJ
TGJ's Avatar
Exactly...
TGJ is offline
post #5 of 11 (permalink) Old 08-29-2007, 06:46 PM
Yep, the factory loops do not count for NHRA.
I started working on one for my XR7 before getting sidetracked with the engine/trans build. Honestly, I probably won't get back to making the loop until this winter, but I will definitely post up pics and info somewhere on these forums when I do.
-Rod
post #6 of 11 (permalink) Old 09-10-2007, 05:00 PM
Try PRW brand that is what I have on mine. I believe you can go to www.prwonlinestore.com.
j.adkins is offline
post #7 of 11 (permalink) Old 09-10-2007, 06:03 PM
Any pics of it installed?
-Rod
post #8 of 11 (permalink) Old 09-10-2007, 09:06 PM
FordFanatic's Avatar
what is the requirement? could you heat up some re-bar and bend it into shape?
FordFanatic is offline
post #9 of 11 (permalink) Old 09-10-2007, 09:12 PM
....must have a retainer loop 360 degrees of enclosure, 1/4-inch minimum thickness and 2 inches wide, or 7/8-inch x .065-inch welded steel tubing, securely mounted and located within 6 inches of the front universal joint for support of the driveshaft in event of U-joint failure.....
That's straight from the NHRA rulebook. Making one out of re-bar will get you sent home.
-Rod
post #10 of 11 (permalink) Old 09-10-2007, 09:14 PM
dzzzamn
post #11 of 11 (permalink) Old 09-10-2007, 09:24 PM
If you're running on street tires, in a 14 second or slower car, most tracks aren't going to check for things like a driveshaft safety loop. However, they do tend to be pretty picky about the quicker cars with slicks.
-Rod
