Help put a trans in a car now no crank - TCCoA Forums
post #1 of 9 (permalink) Old 10-09-2007, 05:26 PM Thread Starter
Hey guys Im having a little bit of trouble I just put a used trans into a 93 mark. Got in it to start it and it doesn't crank... I figured it was the MLPS but i played with that for a while and even used 2 different ones and still nothing. The harness came from the trans that was in the junkyard so I am not sure if that could be a problem or not.
staffamerica74 is offline
post #2 of 9 (permalink) Old 10-09-2007, 06:36 PM
Are you getting a click from the starter at all?
-Rod
post #3 of 9 (permalink) Old 10-09-2007, 08:10 PM
one in a million
Nightstar's Avatar
check the starter wire going to the starter solenoid...
I broke mine when changing my transmission and had to rig it because the wire clip broke..
Nightstar is offline
post #4 of 9 (permalink) Old 10-09-2007, 08:20 PM
95xbird's Avatar
What kinda car did the trans come from???And yes check the wire going into the tab on the starter.Is your converter seated properly???
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 9 (permalink) Old 10-10-2007, 08:52 AM
02 Explorer Pioneer
timb's Avatar
We definitely need to know what the new trans came out of. Did you use the Mark MLPS?
Birdless
timb is offline
post #6 of 9 (permalink) Old 10-12-2007, 08:44 AM
tbirdtess's Avatar
converter
Hello
Make sure the Torque converter is all the way into the transmission.
It is easy to miss the last input. I have even done it.
loosen the bolts to the trany. see if you can bump the engine. if she now turns you must unbolt the converter. push the trany back. set the converter all the way in, then slide the trany back in place.
I change a coupe of the bolts to longer one's so to keep engine alignment & give some room to re-seat the converter. Realign the converter studs & slide the trany to the engine. Do not pull on the studs until the trany is bolted in. Then reinstall the converter nuts. You will need to turn the engine to install the nuts.
Now you know the engine turns.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #7 of 9 (permalink) Old 10-19-2007, 03:18 PM Thread Starter
Sorry I was away on vacation for a week. Anyhow the Trans i put in the mark came from a 94 mark. There was no clicking or anything when turning the key the shifter in this car seems a little funky as in loose well compared to mine. Ill give the idea about loosening the trans a little a shot. Could be the starter tab because it was hanging for a week or so.
I kept playing with the shifter and linkage the entire time but nothing. The MLPS was aligned pretty well too.
post #8 of 9 (permalink) Old 10-19-2007, 05:21 PM
ditto very important
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #9 of 9 (permalink) Old 10-19-2007, 09:36 PM
The mlps must be perfect. check the adjustment and make sure it is connected well. Check the cable adjustment as well. adjust it in neutral to the center of the N.
