AODE to 4R70W harness question - TCCoA Forums
post #1 of 16 (permalink) Old 10-23-2007, 07:10 PM Thread Starter
ROLLINTHUNDER's Avatar
I have a 95 bird and a 97 mark viii parts car. Im putting the mark motor in using my bird harness. Is there any way to make the 4r70w tranny work with the bird harness?Thanks.
ROLLINTHUNDER is offline
post #2 of 16 (permalink) Old 10-23-2007, 07:52 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
They are both 4R70W. I thought it is supposed to hook right up. Wasn't the wiring change for the 98's and up?
tinman_72 is offline
post #3 of 16 (permalink) Old 10-23-2007, 07:55 PM Thread Starter
Im not sure. I thought I read somewhere that the 4r70w had an extra solenoid or sensor or something and something about the plugs being different.
post #4 of 16 (permalink) Old 10-23-2007, 07:57 PM
They are both 4R70W's and the connector should be the same. You need to use your TCC solenoid though from your 95 in the 97 trans.
post #5 of 16 (permalink) Old 10-24-2007, 05:18 PM Thread Starter
Where abouts is the TCC solenoid located?Oh, and sorry for asking the same question. Weekend is getting here fast and im just teying to figure out as much as possible for the guy thats doing the swap.
post #6 of 16 (permalink) Old 10-24-2007, 05:18 PM
It's inside the transmission. Pan needs to come off to access it.
post #7 of 16 (permalink) Old 10-24-2007, 05:30 PM Thread Starter
Yeah my friend was saying something about swaping the valve bodies. Is that where its at?
post #8 of 16 (permalink) Old 10-24-2007, 07:17 PM
tinman_72's Avatar
You are gonna want to keep all the parts on the '97 tranny, except for that TCC solenoid. You can find its location in the tech articles.
post #9 of 16 (permalink) Old 10-24-2007, 07:32 PM
Yes the solenoid goes into the valve body, but you only need to swap the solenoid. Swapping anything else would be taking a step backwards in terms of design.
post #10 of 16 (permalink) Old 11-01-2007, 06:52 PM Thread Starter
Would it be a good idea to go ahead and just use all of my t-bird solenoids in the mark tranny?
post #11 of 16 (permalink) Old 11-01-2007, 08:51 PM
No. Just change out the TCC solenoid.
-Rod
post #12 of 16 (permalink) Old 11-01-2007, 10:57 PM
^^ What he said and what I said earlier. No need to make it any more complicated.
post #13 of 16 (permalink) Old 11-02-2007, 05:21 PM Thread Starter
I completely get the point on that! Thanks alot to you both. Really appreciated all the help.
post #14 of 16 (permalink) Old 11-06-2007, 08:13 PM Thread Starter
Got the TCC solenoid changed over and the birds tranny harness hooked up. Just out of curiosity why do you change over the TCC solenoid?
post #15 of 16 (permalink) Old 11-07-2007, 04:10 AM
Because the resistances are different between the two solenoids and using the incorrect one will damage the PCM or otherwise cause a malfunction.
post #16 of 16 (permalink) Old 11-09-2007, 06:08 PM Thread Starter
The car fired right up and drove and shifted fine. Thanks guys!
