dumb trans question - TCCoA Forums
post #1 of 21 (permalink) Old 01-28-2008, 01:10 PM Thread Starter
dumb trans question
alright i think i know the answer to this so i thought i'd post in here.
i was driving home and i saw what looked to be a 94 or newer super coupe
i stop to knock on the door to see whats going on with the car and it needs a trans to make it better the whole time i'm talking to the wife of the owner.
she said it needs a trans and she just wants it gone its been sitting for a year i ask for keys she brings them out i throw my battery in and it fires right up no smoke sqeaks rattles perfect fluid levels i say how much she says 200 bucks and its mine.
would the trans out of my 93 v-6 bird drop right in without any issues?
and is there anything i should lookout for?
i always wanted a sc but i have enough vehicles that need work right now.
so i just want to make sure i can rescue this one without going in over my head.
like i said i think the trans i have will fit right in but i just wanted to be sure.
thanks in advace.
also if for some reason theres alot of rot in the floors how hard would it be to drop in the 94 or newer motor and all in my 93 n/a v-6 car.
just wanting to see what my options are.
DOHC-BIRD is offline
post #2 of 21 (permalink) Old 01-28-2008, 03:30 PM
You must use a 94 or later transmission in a 94/95 SC. 93 and earlier are AOD and 94+ are 4R70W. You can use any year 4R70W from a 3.8L, but you might have to swap components to get it to work.
post #3 of 21 (permalink) Old 01-28-2008, 03:30 PM
93 is an AOD, 94 with an auto is an 4R70W, lots of differences, not an easy swap either way.
Bangster is offline
post #4 of 21 (permalink) Old 01-28-2008, 03:48 PM
351cat's Avatar
Send a message via AIM to 351cat
it'll bolt up, but it wont shift... the 94 is electronically controlled, the 93 uses a throttle valve cable which the 94 wont have... plus i think the driveshaft will be a different length
Originally Posted by Mitch Hedberg
"Escalator Temporarily Stairs. Sorry For The Convenience."
Originally Posted by cougar_guy04 View Post
Red Green, is that you? Might consider looking into fabbing an intake setup that isn't so, well, ghetto.
351cat is offline
post #5 of 21 (permalink) Old 01-28-2008, 04:21 PM Thread Starter
if i swapped over the t.v cable from the 93 it still wont work i take it.
post #6 of 21 (permalink) Old 01-28-2008, 05:38 PM
Nope, because it has nowhere to attach on the other end. This car wasn't designed to have the TV cable.
Jay
FordMan77 is offline
post #7 of 21 (permalink) Old 01-28-2008, 05:55 PM Thread Starter
true but here are plenty at the j/y that were.
i guess the answer is it aint gonna happen without the right trans.
which is ok.
post #8 of 21 (permalink) Old 01-28-2008, 05:55 PM
EuroBird's Avatar
Send a message via MSN to EuroBird
If it were me....
It runs fine? Interior and bodywork ok?
BUY IT. Go to the woman (not the husband) with 150 cash in hand and close the deal. I'm sure you can scrounge up a working 4R70W at a local yard or even here somewhere. Seeing as you'd have to replace the trans anyway throw, do a shift kit and cooler and you'll have sweet ride. The newer interior, SC...I'm jealous!
What's the prob with the trans? No OD? Simply toast? Did you put it in gear?
Guys/galls am I right that their are no 'stupid questions' just stupid answers?
Anyways, if it were me, I'd SCoop it up!
90 Chevy c1500
78 Jag xj6
78 Volvo 245 b230fk turbo
72 VW Beetle Subaru EJ20
72 MGB GM v6/t5
67 Volvo Amazon Wagon
65 Volvo Duette
64 Volvo PV544
62 Volvo Amazon Coupe
56 Ford Popular 302/AODE
52 Chevy 3100, 454/700r4
EuroBird is offline
post #9 of 21 (permalink) Old 01-28-2008, 11:48 PM Thread Starter
i really want to but...
i have a 94 mark viii needs a trans
just picked up a 93 3.8 bird beautiful car with a rod knock ended up puttuing a whole in the oil pan no biggie paid $250 definitly worth the money its a clean car.
g/f car no heat 94 4.6 bird .
my space is getting full.
although the s/c is a decent car itself it still needs a few other things besides a trans but the trans is the only mechanical issue.
if i do pick it up i'll take some pictures and throw her on here for another member to rescue.
its definitly worth it.
the trans is completely gone tho i put her and each gear and nothing.
post #10 of 21 (permalink) Old 01-29-2008, 02:21 AM
Gcline's Avatar
could be the trans control module is out.
Daily Driver, 38mpg!
Gcline is offline
post #11 of 21 (permalink) Old 01-29-2008, 07:06 AM
dDUBb's Avatar
Jay
Actually, you can hook up the TV cable to the 94/95 SC Throttle body .. just add the grommet to the linkage if it doesnt already have it.
You can make it work, but it will have issues with the EEC - so that would need to be programmed to remove the transmission, or possibly use a manual EEC.
This would be taking a huge step backwards though .. I would just rebuild the 4r70w already in it, or pick up a newer 4r and rebuild that so it is up so the SC specs.
If it wont go anywhere when put in gear, check the fluid level. The transmission should still have Reverse and 2nd gear unless something is broken internally.
dDUBb is offline
post #12 of 21 (permalink) Old 01-29-2008, 07:32 AM
joshbea6's Avatar
Maybe the trans fluid is low.....
an SC for $200? Where is it? I'll take it if you don't want it!
joshbea6 is offline
post #13 of 21 (permalink) Old 01-29-2008, 11:24 AM Thread Starter
checked the fluid and its full smells horrible but its full.
the car is located in gary,indiana
the husband gave me a call today i'm meeting up with him on friday.
not to sound shady but it doesnt even sound like he knows what he has.
i'll let you guys know how it goes .
if anything i'll pick it up and turn around and sell it here.
post #14 of 21 (permalink) Old 01-29-2008, 12:37 PM
Since the trans is on the way out, I'm sure he parked it and just doesn't want to deal w/ putting a new one in a 14 year old car. Most people could probably care less that it's an SC, or even a T-bird for that matter. They just see it as transportation.
It's not shady at all to offer a low amount of money for it. If he really cared about it he would have fixed it by now. He gets the $150, which is more than a j-yard would probably give him, it's out of his way, and you get an SC for practically nothing. If his wife is anything like mine, she's probably been nagging him to get rid of it for a while now anyways All you need to do is find a newer 4R and throw it in and call it a day. Heck, you could prob. replace the trans. and turn around and sell it for profit.
Jay
post #15 of 21 (permalink) Old 01-29-2008, 12:52 PM
Triple-X's Avatar
$200 for an SC? You would have to be CRAZY not to get that, If it were me I would have jumped on it whenever she told me it was $200. There is a 84 Turbo Tbird around the corner from my house for sale for $500, It needs a little body work but nothing major, But it won't start, It will turn over and sounds fine but it won't start. The guy says he has done EVERYTHING he can think of to get it to start and he says that it just won't. I think that the timing is off and that's why it won't start, But that's just me. I am debating HEAVILY on getting it, But I'm pretty sure that the guy won't go any lower than $500, He says that there is $1,200 worth of parts in it that he just put in before it stopped working, I only seen a new valve cover gasket, Some new wires and a new selinoid. Do you think that the car is worth $500?
My old 5.0 MN12
http://www.cardomain.com/ride/2942310
Horsepower is how fast you hit the wall, Torque is how far you take the wall with you......
Triple-X is offline
post #16 of 21 (permalink) Old 01-29-2008, 02:01 PM
What is that exactly?
post #17 of 21 (permalink) Old 01-29-2008, 02:04 PM Thread Starter
any car is only worth so much without hearing it run is kinda like flying blind.
i'm pretty sure its the timing belt.
which is easy on those cars.
change it and put the car on turboford.net.
post #18 of 21 (permalink) Old 01-29-2008, 02:55 PM
Triple-X's Avatar
The timing belt? Hmmm... Never thought of that. But if it has the timing belt on it and it spins when the engine turns over, Could it still be it?
My old 5.0 MN12
Triple-X is offline
post #19 of 21 (permalink) Old 01-29-2008, 05:00 PM
Could have jumped if the belt is worn I would think.
Jay
post #20 of 21 (permalink) Old 01-29-2008, 05:08 PM
VicRattlehead's Avatar
if you dont get it let me know ill go get it.
CMP Drag Racing
VicRattlehead is offline
post #21 of 21 (permalink) Old 01-29-2008, 08:30 PM Thread Starter
i let you guys know what happens after i talk to them on friday
