how to free up room to add a B&M transmission cooler with fan - TCCoA Forums
post #1 of 6 (permalink) Old 01-31-2008, 07:17 PM Thread Starter
On Probation
blown96bird's Avatar
Part of the problem adding a B&M Transmission cooler with a fan is the lack of space due to power steering cooler interference. I found more room by using a early 90s Taurus power steering cooler It allows 2 additional inches of clearance I did have to trim about 1 inch off the hoses and drill 2 new holes.
blown96bird is offline
post #2 of 6 (permalink) Old 01-31-2008, 08:54 PM
hugh?
post #3 of 6 (permalink) Old 01-31-2008, 09:37 PM
what supergordo and I did when we put on in his brothers bird was just bend the brackets on the cooler... i don't recall if it was bent up or down but I know we bent the brackets to so the stock cooler would clear. PS invest $5 in some better hose clamps!
post #4 of 6 (permalink) Old 02-01-2008, 01:23 AM
SuperNewbie
supergordo's Avatar
We bent the brackets downward just a little bit.
If you want to compare notes:
http://forums.tccoa.com/showthread.php?t=103309
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #5 of 6 (permalink) Old 02-01-2008, 07:12 AM
nickmckinney's Avatar
I bought the biggest cooler Summit made and squeezed it between the radiator and condenser. Tranny never gets over 160F in the Florida summer.
nickmckinney is offline
post #6 of 6 (permalink) Old 02-02-2008, 12:06 AM
3rd Gear Chirper
hotbird's Avatar
I bent my factory cooler out of the way like was previously mentioned in this thread. It never did much for cooling the way it was placed, so I eliminated it altogether and haven't had a problem with the oil overheating at all. I run Mercon in there, not generic hydraulic steering oil, and it seems to work well and stay cleaner too.
Next I'm going to make up some -AN lines, I don't know what Ford was thinking when they designed the high pressure side of the system, but the line runs all over the place before connecting to the inlet port on the rack.
hotbird is offline
