question on part compatability - TCCoA Forums
post #1 of 7 (permalink) Old 03-13-2008, 01:26 PM Thread Starter
Will a 28 spline traction lock posi out of a Mustang which worked fine when removed work in a mark 3.73 build up?
post #2 of 7 (permalink) Old 03-13-2008, 01:31 PM
it will fit just fine per say, but if you use the circlips that are on the axles, you might have a real hard time trying to reomve them afterwards.....options are, get some side gears for the t-lock that are for an IRS, get the mustang side gears machined, or just do away with the circlips..
post #3 of 7 (permalink) Old 03-13-2008, 01:31 PM
Yes and no....
Yes it will fit, and everything will bolt together. Just don't ever plan on removing your half shafts again.
Just as kdanner his opinion....
http://forums.tccoa.com/showthread.php?t=108693
69 F100 LWB w/460 Engine
post #4 of 7 (permalink) Old 03-13-2008, 01:58 PM Thread Starter
ahh so its not the best of ideas to go with this. I don't mind if I needed to pay for a rebuild but I don't know who could do the machining. This is going to be put together by a reputable shop. Do you think they would understand what would be needed to make this work? I'm want a mark pumpkin rebuilt with a SCP.com kit and 3.73s ring n pin set(all of which I have minus the track gear). I was offered this part because of the wanted posting I put up. I don't want to make things harder than they need to be, should I pass on the part?
post #5 of 7 (permalink) Old 03-13-2008, 02:03 PM
I'm pretty sure the side gears are available from the dealership and aren't too expensive.
Can't hurt to call and get a price.
post #6 of 7 (permalink) Old 03-13-2008, 10:00 PM Thread Starter
Ill consider the side gears option. I guess removing the circlip is cheap but a time eater. Would a shop have any reason to refuse the part if I removed the circlips? Also is it tough to remove them, I have an idea where they are but I've never read about how tough it is to dismantle a spider gear. Thanks for the quick replies, I hope to get this project rolling asap.
post #7 of 7 (permalink) Old 03-13-2008, 10:39 PM
Send me the side gears I'll machine them for you.
