How hard to swap the whole trans? - TCCoA Forums
post #1 of 12 (permalink) Old 04-08-2008, 11:24 PM Thread Starter
PDL2MDL
krazy4's Avatar
Okay, I don't have enough money to have a shop rebuild the trans for me. I want to get a trans out of, say a 99-04 GT. How hard is the swap? I think i have to swap a few things from my car onto that trans, but other than that isn't just plug and play.
I can't rebuild a trans by myself but I can do most of the other stuff
Thanks for the help guys, and where is a good source for a slightly used 4R70W?
Thanks again.
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #2 of 12 (permalink) Old 04-08-2008, 11:27 PM
check car-part.com for the trans. you'll have to re pin your harness connector and swap in your tcc solenoid, and if you use the gt converter you'll need a flexplate.
post #3 of 12 (permalink) Old 04-09-2008, 12:02 AM Thread Starter
PDL2MDL
krazy4's Avatar
Thumbs up
I found a trans. that is close to me for $450. Think it is a pretty good deal, and the mustang only had 22,000 miles on it. What is involved in repinning the harness connector? I'm pretty sure the tcc just goes in. Would the trans. include the flexplate or would I have to buy that separately?
Sorry for the noob questions.
Automatic transmissions>me
Thanks for the quick reply and your help
cone filter
krazy4 is offline
post #4 of 12 (permalink) Old 04-09-2008, 08:26 AM
You would have to buy the flexplate separately. Repinning the connector is just pulling the wires out of the pin location they are in, and moving them to the proper pin location for the mustang trans. The TCC solenoid will swap right in, so that's no problem there.
Automatic transmissions are actually quite simple once you start messing with them. For some reason, they just scare people at first.
post #5 of 12 (permalink) Old 04-09-2008, 12:39 PM
don't forget to change the speedometer gear accordingly.
post #6 of 12 (permalink) Old 04-09-2008, 02:53 PM Thread Starter
PDL2MDL
krazy4's Avatar
Pretty sure my car has 3.27 gears in in right now, what speedo gear would I have to get.
I spin 2,000 rpm at 70mph right now. I think that is 3.27.
Thanks for all of the help guys!
cone filter
krazy4 is offline
post #7 of 12 (permalink) Old 04-09-2008, 02:56 PM
21 tooth purple.
post #8 of 12 (permalink) Old 04-09-2008, 03:11 PM Thread Starter
PDL2MDL
krazy4's Avatar
Alright thanks!
Definately gonna do this than do the rebuild sooooooo much cheaper. This is gonna take time away from my other project though. 68 barracuda.
Typically how long does a trans swap take. I would guess a whole weekend working pretty much the whole time, maybe even more.
Thanks again guys!
cone filter
krazy4 is offline
post #9 of 12 (permalink) Old 04-09-2008, 03:18 PM
paintme205's Avatar
i did my entire trans swap by myself except someone handing tools and lowering a jack in 5 hours including a flexplate change. you should have no problem doing it in a weekend if you have never done it.
luke
paintme205 is offline
post #10 of 12 (permalink) Old 04-09-2008, 06:49 PM
well nice for you guys with no snow and salt ahaha up here in Boston doing a trans in a day may not be the case, those rusted bolts can really slow you down
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #11 of 12 (permalink) Old 04-09-2008, 07:12 PM
You should definitely be able to do it in a day. NJ isn't much better for salt and rusted bolts. The one thing that's a PITA about it is that on our cars, the driveshaft goes over top of the gas tank, so make sure the tank is almost empty, then you can unbolt the straps and just let the tank hang down, and that will give you enough room to get the driveshaft out. Oh, also use a long extension with a swivel socket going in from the front to get to the top bolt for the starter. Other than that, everything about the swap is pretty straightforward.
post #12 of 12 (permalink) Old 04-10-2008, 01:18 PM Thread Starter
PDL2MDL
krazy4's Avatar
Okay, so it doesn't sound like it will be that hard.
I am probably going to do this, then have the bird be road ready again.
cone filter
krazy4 is offline
