trans with higher fourth gear - TCCoA Forums
post #1 of 2 (permalink) Old 05-03-2008, 02:16 AM Thread Starter
paintme205's Avatar
does anyone make a 4r70w with a higher fourth gear ratio. I want lower rpms in fourth gear when combined with 4:10s or 4:30s. i think stock is 070 right?
paintme205 is offline
post #2 of 2 (permalink) Old 05-03-2008, 08:14 AM
automatic transmissions don't work that way. They have a planetary gearset so you can't change one gear without changing all the others too. And as far as I know, the only other gearset you could use would be the AOD, which has a .67 top gear instead of a .70, but first and second in the 4R70 are much steeper, so you would lose a lot of acceleration doing that, all for practically nothing on top end.
