interior getting very warm - possibly overheating? - TCCoA Forums
post #1 of 16 (permalink) Old 05-09-2008, 10:11 AM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
im guessing this is a tranny issue.
it seems that the tranny tunnel and my center console are warmer than normal. i have a tranny cooler, and i didnt install the carpet padding surrounding the tunnel when i swapped to a mark viii carpet. shifting seems normal. i was told that ford installed insulation in the tranny tunnel to block heat from getting into the cabin, yet i didnt see any insulation on my 93 when i pulled the drivetrain.
would the padding make that much of a difference, or am i on the verge of a failing 4r? not having a/c and this issue are not a good combo in a black car with black seats IN houston!
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 16 (permalink) Old 05-09-2008, 10:19 AM
Save the Panther
Southpaw's Avatar
then fix the a/c already...
Being in SWFL I don't know how i got by as long as i did before fixed mine. I replaced everything in the refrigerent loop except the compressor manifold and the evap core. Both of which i flushed out with alcohol and compressed air.
anyway, did you notice increased temps as soon as you swapped the carpet and padding out?
97' Cougar XR7 - Sport Option, 4 Wheel Disc w/ ABS, Moon Roof, Leather Interior, Leather Wrap Wheel & Shifter, Cruise Control, Power Drivers Seat, Power Lock Group, Premium Sound, Power Antenna, K&N Panel Filter - Hey, It came with the car! Florida Panther Society
Southpaw is offline
post #3 of 16 (permalink) Old 05-09-2008, 10:29 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
im working on it. i got a guy helping me next week with it. replacing almost everything after locking up the compressor
i didnt notice it right after. it gradually got warmer. it doesnt seem normal for it to get that warm in there.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 16 (permalink) Old 05-09-2008, 02:03 PM
Mine gets quite hot, and I don't remember it being like that before my engine swap. But I don't know. I installed the padding and all insulation.
post #5 of 16 (permalink) Old 05-09-2008, 10:13 PM
Xan
It seems most cars get warm in that area when it gets warmer out, not saying you should rule out this as a sign of a problem but it seems normal to a degree. But if its not normal for your car, have you considered it might be an exhaust leak?
Xan is offline
post #6 of 16 (permalink) Old 05-10-2008, 08:16 AM
well that thing gets like 160 degrees EASY. mine gets warm all the time. Alot of shifting and slow moving traffic will probably have something to do with it.
FunktasticLucky is offline
post #7 of 16 (permalink) Old 05-16-2008, 08:41 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
done. that seemed to fix it
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 16 (permalink) Old 05-16-2008, 11:06 AM
LOLA's Avatar
I think's it because you are closer to the floor and trans tunnel than most
LOLA is offline
post #9 of 16 (permalink) Old 05-19-2008, 12:10 AM
94trouble's Avatar
Send a message via AIM to 94trouble
sorry that was funny,and my car gets warm in that area too
Wrecked my 94LX looking to get another car.
94trouble is offline
post #10 of 16 (permalink) Old 05-19-2008, 01:28 AM
My 95 Cougar doesn't get warm at all in that area, with stock trans (slippage anyone?) and no cooler.
My 94SC gets hot enough to feel it if you put your hand above the trans tunnel.
'94 SC - Black on Blue. Currently KIA due to drunk driver.
'95 SC - Black on Grey. 45K Miles. Converting to the darkside.
'02 Lincoln LS V8- Black on Grey. Daily Driver.
95XR7 is offline
post #11 of 16 (permalink) Old 05-19-2008, 02:49 AM
mine does and I'm in AZ. I put a huge trans cooler on it and its still warm by one leg in the summer time. I also thought I felt it was coming from the exhaust manifolds seriously its like my heater is on all the time sometimes it gets so hot. So you're not the only one Big Mike feelin heat. I'm purchasing a set of ceramic coated manifolds to combat underhood temps. A trans cooler also helps too.
post #12 of 16 (permalink) Old 05-19-2008, 07:55 AM
LOLA's Avatar
I experience this in my '97 4.6 and I experienced it in my '92 3.8 NA.
LOLA is offline
post #13 of 16 (permalink) Old 05-25-2008, 10:59 AM
I have the center console out of my 89, and the spot under the console at the very back does NOT have any carpet or the "blanket" the rest of the interior has, and after about 12 minutes of driving that spot is hot enough to leave marks on skin that touches it. Ask my elbow! It gets smokin hot, and I don't think it is an problem with the tranny getting over temp, just the way it is.
Bangster is offline
post #14 of 16 (permalink) Old 06-09-2008, 09:40 PM
lowbird96's Avatar
your cats are sort of in that area if one of them is clogged it would get verry hot dont know if thats the problem but couldnt hurt checkin it
lowbird96 is offline
post #15 of 16 (permalink) Old 06-11-2008, 09:27 PM
Before my tranny died a couple of years ago, it baked the inside of the car pretty well.
It was still warm the day after I drove it up on ramps to change it out; The mercon was hotter than a normal shower, for sure.
The torque converter and all clutches were slipping by then...but it got me home, anyway.
Grog6 is online now
post #16 of 16 (permalink) Old 06-15-2008, 02:36 AM
thewishkah's Avatar
Send a message via AIM to thewishkah
I noticed this too. I was actually thinking of a way to insulate the tunnel because its really annoying having one leg and arm sweating. I picked up my portable HD (which I plug into my usb port) today and it was really warm from just sitting on the center console.
I have a ton of fatmat(cheaper dynomat) laying around and wonder if it might help? Any thoughts?
thewishkah is offline
