Clicking sound from rear of the car - TCCoA Forums
post #1 of 8 (permalink) Old 05-15-2008, 03:08 PM Thread Starter
I've been hearing a clicking sound that seems to only happen during acceleration from a stop, and also if im speeding up; ie 25 -> 35 mph. If I engine brake, I don't hear it, nor do i hear it when i'm cruising.
Also, theres a bad vibration at around 60 that kinda disappears and then reappears around 80, but that might be engine related.
Any ideas or things i should check for?
cougar618 is offline
post #2 of 8 (permalink) Old 05-15-2008, 03:20 PM
stickysilvertbird's Avatar
for the shuddering.. check your tire pressure.. alignment,etc.. mine did that too until i got new tires and an alignment and it doesnt do it at all now... as for the clicking sounds.. could be a worn u-joint.. it gives the driveshaft some spin slack what your hearing is the driveshaft ctching the slack and tapping the head of the u-joints.. also check your pinion bearing.. if thats going out it could be causing the clicking from the pinion wiggling around
♠Zack♠
stickysilvertbird is offline
post #3 of 8 (permalink) Old 05-15-2008, 06:05 PM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
Rear Wheel Bearing?
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #4 of 8 (permalink) Old 05-15-2008, 11:35 PM Thread Starter
Is there a way for me to check those? I know for a fact that the driveshaft u- joint is bad b/c of the sound it makes going back and forth from reverse to drive.
post #5 of 8 (permalink) Old 06-05-2008, 08:43 PM
get under the car and move the drive shaft by hand.
coffeepot/hrlmk7 is offline
post #6 of 8 (permalink) Old 06-05-2008, 09:00 PM
rbrown's Avatar
Originally Posted by SC V8 Bird View Post
Rear Wheel Bearing?
You know mine does make sounds while braking too. Kind of a creak creak creak.
And the shake at certain speeds.
Never thought about a rear wheel bearing.
Hmmmmm.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #7 of 8 (permalink) Old 06-05-2008, 11:57 PM Thread Starter
its not the drive shaft.. that's another problem that i have and i'm aware of it. the clicking sound is repeated.. it clicks like 5 or 6 times each one faster when i'm accelerating.
post #8 of 8 (permalink) Old 06-06-2008, 12:30 AM
SC V8 Bird's Avatar
Rear Wheel Bearing?
Have you ruled out the wheel bearings?
Mine had similar symptoms you are describing.
SC V8 BIRD
TCCoA Gallery
Car Domain
