Driveway vs. 4R70W...how badly did I break it? - TCCoA Forums
post #1 of 6 (permalink) Old 06-15-2008, 09:19 PM Thread Starter
3rd Gear Chirper
hotbird's Avatar
Okay, I had a moment of stupidity today, lol. I was cleaning up the trans from the 97 and had it sitting in the driveway. Went to leave to go to the store and began to back around it, and then I stopped because I forgot my wallet in the garage. At this point, the trans was hidden from view behind the car, and I forgot it was there so when I went to leave again I gave it a nice smack.
It was sitting about a foot off the ground on a cart, and I don't know if I hit the trans or the cart. It landed upside down with the converter still in place and fully seated, but the extension housing is cracked where the tailshaft seal is (definately from hitting the ground, there are concrete chips), and also it appears to have kissed the ground in the direct clutch area, but no damage visible there, just light concrete scrapes.
The output shaft appears fine, just the housing is cracked and the dipstick is bent, so what are the chances that I damaged the internals of the beast?
hotbird is offline
post #2 of 6 (permalink) Old 06-15-2008, 09:45 PM
sik97bird's Avatar
i would deff be looking at the tailshaft itself and be damn sure it's not bent.
but breaking some of the internals......it's a 50/50 chance i would get it checked out before i went any further.
I'M BACK
97 Supercharged Ford Thunderbird with warpdrive
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #3 of 6 (permalink) Old 06-15-2008, 10:06 PM
i'd worry about some of the bushings and internal seals if it hit that hard
post #4 of 6 (permalink) Old 06-23-2008, 02:38 PM Thread Starter
3rd Gear Chirper
hotbird's Avatar
Okay, here's the deal. I have an old extension housing from a late 90's 4R70W, the oil seal is gone and there are pry marks on the face of the seal area but not on the actual bore where the seal would fit into. The bushing is intact, but has quite a few miles on it so I'd like to replace it.
I called my local Ford dealer and he says the tailshaft bushing is not serviced separately, I need to buy the entire extension housing for $151.00. Dude says it should come with the oil seal, but if not it's only $13 to get that too.
So, should I just buy a new extension housing and know that all is well, or should I get an aftermarket bushing of apparently questionable tolerances, and stick it in my used housing and hope for the best?
hotbird is offline
post #5 of 6 (permalink) Old 06-23-2008, 02:48 PM
I would say get the new one if you have the money.
When you factor in the time to install an unknown tolerance bushing and seal into a used extension housing, the $151 doesn't look too bad for a "bolt on and go".
69 F100 LWB w/460 Engine
post #6 of 6 (permalink) Old 06-26-2008, 08:39 PM Thread Starter
3rd Gear Chirper
hotbird's Avatar
Yeah, you're right. New housing it is!
hotbird is offline
