Problem with codes - TCCoA Forums
post #1 of 2 (permalink) Old 07-22-2008, 06:44 PM Thread Starter
Problem with codes
I pulled into my driveway today and put my 96 4,6 in park and it just kept reving to about 1400 rpms. I just replaced the IAC only because the car has 121k on it. I hooked up my OBDII scan tool and I get PO102 but there is no check engine light.
(Mass or Volume Air Flow Circuit Low Input) is what the code means but what do I look for or check??? MAF has been cleaned and looks perfect. Did the wiggle test on any wires I could find. Anyone know what could be causing this? Thanks
scbird is offline
post #2 of 2 (permalink) Old 07-22-2008, 07:23 PM
Why is this in the Drivetrain section?
Either the MAF sensor is bad or the TPS sensor is giving false readings.
