94/95 V6 4R70W to AOD swap - TCCoA Forums
post #1 of 13 (permalink) Old 07-30-2008, 04:01 PM Thread Starter
Send a message via AIM to Faster7
What issues might I run into? I know I'll need the TV cable/throttle body setup from a donor non-electronic trans car, but will the ECU have a fit? Any issues with the speedo sensor?
I have complete '90 and '91 donor cars with good transmissions...
Faster7 is offline
post #2 of 13 (permalink) Old 07-30-2008, 05:06 PM
You'll have to change computers to a 93-earlier one because the ECU will go crazy without the transmission. I don't think a tune can turn that off either, but I might be wrong.
post #3 of 13 (permalink) Old 07-31-2008, 08:30 AM
PCD
Confirmed V6 Nut
Why would you swap an AOD for a 4R70W? I've driven a MN12 with both, and I prefer the 4R70W.
PCD is offline
post #4 of 13 (permalink) Old 07-31-2008, 11:27 AM Thread Starter
The 4R70W is toast, and the friend that owns it would like to have it back on the road without spending too much $.
Which ecus should be plug and play? Anything from another 89-95 3.8 non-sc tbird that has a distributor?
Faster7 is offline
post #5 of 13 (permalink) Old 07-31-2008, 12:50 PM
PCD
Confirmed V6 Nut
I would say that you are looking at a 89 to 93 ECU from a LX. The Super Coupes were all DIS.
PCD is offline
post #6 of 13 (permalink) Old 08-01-2008, 10:21 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
correction, 91-93. 89-90 were MAP controlled.
You don't need a new computer though, the computer won't make the engine act funny without a 4r70w it'll just throw a check engine light, that's all.
-Thomas
Thomas is offline
post #7 of 13 (permalink) Old 08-01-2008, 10:22 AM
Uber Luber
Thomas's Avatar
Oh, however, you will need the transmission mount and driveshaft from the AOD car. As well as the shifter and shifter bezel, shift linkage, speedo gear, tv cable, throttle body. That should be it.
-Thomas
Thomas is offline
post #8 of 13 (permalink) Old 09-20-2008, 05:28 AM Thread Starter
-Thomas
We were counting on the mount and driveshaft, as well as throttle body and tv cable. What is the issue with the shifter? We're ok with having the shift pattern be different from indicated if that's the only issue.
Faster7 is offline
post #9 of 13 (permalink) Old 09-21-2008, 10:19 AM
Uber Luber
Thomas's Avatar
Well the shifter itself might work then. But the OD button will be useless. And the linkage might be different but Im not sure.
-Thomas
Thomas is offline
post #10 of 13 (permalink) Old 01-12-2009, 11:09 AM Thread Starter
Well... it's in and runs fine. Did need to swap driveshaft and crossmember due to minor differences that I could have worked around.
Looking for a wiring diagram to find which pin goes from the EEC to the "OD OFF" light. It runs fine on the stock ECU so we're leaving it in place, but would like to not have the "OD OFF" light flashing as it's doing right now....
Faster7 is offline
post #11 of 13 (permalink) Old 01-12-2009, 02:08 PM
dDUBb's Avatar
Your OD light is flashing because your EEC cant find your Transmission.
Why bother looking for a pin, just take the light bulb out the dash since thats the easier thing to do.
Im surprised it even runs right - when I had an electronic failure in my Tranny the EEC went into limp mode and ran like a lawnmower.
dDUBb is online now
post #12 of 13 (permalink) Old 01-12-2009, 04:52 PM Thread Starter
I can get to any wire in the EEC harness in <2 minutes. Is the dash really easier than that?
Faster7 is offline
post #13 of 13 (permalink) Old 01-14-2009, 08:25 AM Thread Starter
Pin 55, white with light green stripe. No more light.
Faster7 is offline
