1995 Aerostar trans problem - TCCoA Forums
post #1 of 2 (permalink) Old 08-11-2008, 09:08 PM Thread Starter
Exclamation 1995 Aerostar trans problem
This is a 1995 Aerostar with a 3.0 liter V/6 and an auto overdrive.The problem I have is at steady speeds above 45 it is shifting from drive to overdrive for no reason.The trans fluid is good and it does not slip.
park7163 is offline
post #2 of 2 (permalink) Old 08-11-2008, 09:40 PM
A4LD, those have an electronic shift control, they are basically a C3 with an overdrive added to the front of them. They are also electronically controlled lockup TC I think also. Does the speedometer and cruise both work?
That isn't the usual problem that occurs with them, but I think it is pretty common. Usually when they break they stop working when OD is selected, but when you start out and drive in D they are fine. I tracked down a few issues on one in an 89 or 90 Mustang 4 banger.
Bangster is offline
