transmission replace - TCCoA Forums
post #1 of 4 (permalink) Old 10-18-2008, 11:33 PM Thread Starter
My 93 Thunderbird 3.8 v6 automatic transmission is broken, I can 4r70w or aode / w to replace it?
rarely is offline
post #2 of 4 (permalink) Old 10-18-2008, 11:57 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
The 4R70W and AODE are electronically controlled. You would either have to do a computer swap along with a bunch of wiring or you will have to buy a stand alone controller. I highly recommend finding (or rebuilding) an AOD to go back in.
tinman_72 is offline
post #3 of 4 (permalink) Old 10-19-2008, 12:46 AM Thread Starter
first thanks you help!
i'm in china here maintenance costs is very high +500$ USD . but used transmission is only 150-200$ USD . That is why I tend to replace all the transmission or the engine and transmission assembly.
If I replace the transmission. Is buying a transmission stand alone controller "Baumannator TCS™ for Ford Electronic Transmissions" with old eec iv ecu? or any other changes need to place?
rarely is offline
post #4 of 4 (permalink) Old 10-19-2008, 12:53 PM
tinman_72's Avatar
Yes, I believe the Baumanator is all you need but I have not had any experience with it. I believe a few people here have done it, maybe they will speak out.
Make sure that the 4R70W or AODE that you get has the correct bellhousing pattern. Since you have a 3.8 it has the small block Ford pattern (3.8V6, 302/5.0, 351/5.8), not the modular pattern (4.6/5.4).
