Transmission fluid.... - TCCoA Forums
post #1 of 9 (permalink) Old 01-02-2009, 12:58 AM Thread Starter
GilroyRacing's Avatar
Just curious as to wich fluid would be better for my 95 bird.....
Mercon® V ATF
or.......
MaxLife DEX/MERC ATF
GilroyRacing is offline
post #2 of 9 (permalink) Old 01-02-2009, 01:47 AM
VicRattlehead's Avatar
mercon v
CMP Drag Racing
VicRattlehead is offline
post #3 of 9 (permalink) Old 01-02-2009, 09:53 AM
R8D-XXX's Avatar
Mercon V for sure but I would just run regular and not synthetic.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #4 of 9 (permalink) Old 01-02-2009, 12:14 PM
mercon v is synthetic
CMP Drag Racing
post #5 of 9 (permalink) Old 01-02-2009, 08:15 PM
R8D-XXX's Avatar
You can buy the valvoline Mercon V as shown above but NOT fully synthetic. I just put 12 QTS of it in my car the other day when I changed it.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #6 of 9 (permalink) Old 01-03-2009, 12:19 AM
Traveler's Avatar
IF you go Mercon V in a 95 (and it is a good idea) be sure you do a complete fluid change. drain the transmission AND the Torque Converter. Its not a good idea to be mixing fluid types, or at least that's what I've been told.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 9 (permalink) Old 01-10-2009, 07:39 PM Thread Starter
I planned on changing all off the fluid including changing the torque converter
post #8 of 9 (permalink) Old 01-11-2009, 05:42 AM
Jeremys95Thunderbird's Avatar
What about Royal purple ATF? Has anyone tried that?
http://www.royalpurple.com/transmission-fluid.html
1995 LX 4.6 Stock for now.
Jeremys95Thunderbird is offline
post #9 of 9 (permalink) Old 01-11-2009, 10:13 AM
I have never been a fan of royal purple fluids. I believe in maintenance not fluid designed to last forever. I used motorcraft MerconV in mine. If I wanted to go to a synthetic fluid I would probably go with amsoil because they do make a fluid specifically for the merconV.
