Popping / tack, tack,tack @ Take off - TCCoA Forums
post #1 of 33 (permalink) Old 01-11-2009, 11:55 AM Thread Starter
Maic's Avatar
Hey there'
I just re-did my rear end and still have this noise coming from my Rear-end. I don't know what else to look for. May it be the Gear's ?
Replaced:
Toe Compensator Link; Wheel Bearings; Knuckle with Bushings; Axle's(Mark8, used from a very trustful source here).
Everything else is looking good. The Rear diff. was done like 2 Years ago with Poly Bushings. So i need to get the car Aligned and i am totally clueless about what else!
The Noise only appears at take off(like a, when you late for work take off) and there is no popping in Reverse.
Any Ideas??? Thanks.
Maic.
Maic is offline
post #2 of 33 (permalink) Old 01-11-2009, 02:37 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
U joints can squeak when they go bad. Put the car in neutral with the parking brake on, wheels blocked, whatever and check them!
-Rob
Rob is offline
post #3 of 33 (permalink) Old 01-18-2009, 09:11 PM Thread Starter
Maic's Avatar
knocking / Rattling
may it be more an knocking / Rattling !
Changed now the IRS Bushings and and went back to Factory SwayBar Mounts.
What else to look for? The noise appears only @ take off or hart acceleration while driving @ City speeds.
It seems to get worse more i test. It's coming from the rear and does not change @ left/right/straight take off.
Maic.
Maic is offline
post #4 of 33 (permalink) Old 01-18-2009, 09:12 PM Thread Starter
Maic's Avatar
Thanks Rob, but its not an Squeak.
Maic.
Maic is offline
post #5 of 33 (permalink) Old 01-18-2009, 09:28 PM Thread Starter
Maic's Avatar
What for exactly?
Maic.
Maic is offline
post #6 of 33 (permalink) Old 01-20-2009, 03:49 PM
Darrin's Avatar
He means to check them for excessive play and/or noise while rotating.
I sincerely doubt it has anything to do with the extension housing on the transmission. When those have an issue you KNOW it. Leaks around the rear seal and severe vibration on the road make themselves known in a big way.
Darrin
Darrin is offline
post #7 of 33 (permalink) Old 01-20-2009, 04:27 PM Thread Starter
Maic's Avatar
Darrin
No Noise or play from the U-joints.
The rear seal from the housing is leaking and there is a clunking sound when i turn the MMX left/right. May it be the output Shaft bushing and transferring the rattling/popping/groining noise to the back?
It's freaking me out just after all the ReDo !
Maic.
Maic is offline
post #8 of 33 (permalink) Old 01-20-2009, 07:54 PM
Darrin's Avatar
You likely will hear things when you turn the driveshaft left to right.
If the seal is leaking you likely have a problem that is causing it. Usually driveline vibration beats the heck out of the bushing and the leaking starts.
Darrin
Darrin is offline
post #9 of 33 (permalink) Old 01-20-2009, 09:29 PM Thread Starter
Maic's Avatar
Darrin
Nope, the Car is running smooth. Just when i take off with mid gas i have this rattling. After some search here i hope the T-Housing is may loose.
Maic.
Maic is offline
post #10 of 33 (permalink) Old 01-21-2009, 06:40 AM
Darrin's Avatar
Are you talking about the tailshaft housing?
Darrin
Darrin is offline
post #11 of 33 (permalink) Old 01-21-2009, 06:51 AM Thread Starter
Maic's Avatar
Darrin
Yes
Maic.
Maic is offline
post #12 of 33 (permalink) Old 01-21-2009, 06:57 AM
FordFanatic's Avatar
after my little ordeal with tracking down my rattle all i can offer up is a whole hearted good luck.
FordFanatic is offline
post #13 of 33 (permalink) Old 01-21-2009, 07:43 AM Thread Starter
Maic's Avatar
Thank You. I was following your Thread. I wish it was only some Brake pad Rattle
Maic.
Maic is offline
post #14 of 33 (permalink) Old 01-21-2009, 10:35 AM
Darrin's Avatar
If the tailshaft housing itself is loose enough to cause noise I think you would have one heck of a big leak coming from the gasket between it and the transmission and not from the rear seal.
Darrin
Darrin is offline
post #15 of 33 (permalink) Old 01-21-2009, 12:33 PM Thread Starter
Maic's Avatar
Darrin
Makes sense. The Tailshaft Housing looks good and feels tight. I am on the Video Clips now and hope to have them up later. Thanks for staying curious. lol
Maic.
Maic is offline
post #16 of 33 (permalink) Old 01-21-2009, 01:32 PM Thread Starter
Maic's Avatar
Video
Here is a clip from the Tailshaft Housing / Output Shaft.
Here is a clip from the inside, sorry the Exhaust is a lil Loud.
And here from the Back. No rattling.
And this clip closer to the Tailshaft Housing it self. I cant hear nothing but is laoud on the inside of the Car.
Enjoy. lol
Maic.
Maic is offline
post #17 of 33 (permalink) Old 01-23-2009, 04:55 PM Thread Starter
Maic's Avatar
No suggestions anyone ? Darrin !
Maic
Maic.
Maic is offline
post #18 of 33 (permalink) Old 01-23-2009, 06:21 PM
tbirdbrain's Avatar
Sounds like wheel hop and your rear differential mount is beginning to fail. You know anyone that wants wiper arms?
tbirdbrain is offline
post #19 of 33 (permalink) Old 01-23-2009, 08:28 PM Thread Starter
Maic's Avatar
Do the come Brain-coated? No Pres', no wheel hop.The mount is a easy fix' seen it too. Thanks. Last thing it did was that i loosened the Differential Housing and try'ed to center it some. What didn't help. lol
Guess i have to pull the Shaft to have a better look at all. Just not right now no more. Comp. Links, UCA, Power Brake Booster and Master Cylinder came in may way. Two Alignments,etcetera, etcetera. It just never end's.
Anyway, is loud on the inside of the Car and i think the DS is hitting in the Tunnel above the Tank. Soon or later i get it like the rest so far.
Maic.
Maic is offline
post #20 of 33 (permalink) Old 01-23-2009, 08:49 PM Thread Starter
Maic's Avatar
Those from behind the center Console. Just Amplify it and get an idea.lol
Maic.
Maic is offline
post #21 of 33 (permalink) Old 01-23-2009, 09:00 PM
tbirdbrain's Avatar
With the deflection of the differential that you can see in the video, it is certainly possible that the driveshaft is hitting back there.
post #22 of 33 (permalink) Old 01-23-2009, 09:21 PM Thread Starter
Maic's Avatar
I will give it a shot tomorrow. If I but something like a chisel in the Differential rear mount to prevent it from compressing that much it should at least change the noise somehow.
Maic.
Maic is offline
post #23 of 33 (permalink) Old 01-24-2009, 08:51 AM Thread Starter
Maic's Avatar
Just did a test drive. The Rattle is almost gone.
Question now is to but a Bolt in the new used one or weld the Mount like MN12Perf. !
Thanks again Preston
( for test only )
Maic.
Maic is offline
post #24 of 33 (permalink) Old 01-27-2009, 09:22 AM Thread Starter
Maic's Avatar
going crazy
'pulled a new Diff Mount yesterday and installed it. I still had a light rattling after a short test drive. Dropped my son off at Day Care just now and drove a few more times around the block and the rattling is BACK.
Any more suggestions here ?
This the actuall Diff. Mount.
Maic.
Maic is offline
post #25 of 33 (permalink) Old 03-11-2009, 10:46 AM Thread Starter
Maic's Avatar
Update
I pulled the Drive-Shaft today and found where it's hitting.
Here comes my question, can i cut some of this area or is it better to leaf it as is because of chassis stability?
With the Drive-Shaft installed there is only approx. a 1/4" space between DS and Chassis!
Thanks for any Input !
-Maic
Maic.
Maic is offline
post #26 of 33 (permalink) Old 03-11-2009, 12:26 PM
Faster than Porkchop
cjchevez's Avatar
Look for my thread I had the same issue , I took a hammer where it was rubbing .
http://forums.tccoa.com/showthread.php?t=102803 here it is , One of my issues was the transmission shift pressure was way to high on my xcal tune .
I lowered the pressure and I have been driving like this for at least a year .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #27 of 33 (permalink) Old 03-11-2009, 01:05 PM Thread Starter
Maic's Avatar
Just found the Thread and was about to post the Link. Thank you anyway.
Hitting this area with a Hammer is one way, i was thinking of cutting some of this section for max. Clearance!
Will see who else got some input. For now i have to deal with the U-Joints. They still look good but i have them here for just in case. lol
-Maic
Maic.
Maic is offline
post #28 of 33 (permalink) Old 03-11-2009, 01:20 PM
why all of a sudden are we having clearance issues with drive shafts? did something change with them?
other than swapping in a new shaft i would say beating the hell out of it with a bfh is going to be your only solution.
hope it didn't ruin your drive shaft.
post #29 of 33 (permalink) Old 03-11-2009, 01:35 PM
cjchevez's Avatar
-Maic
I did do some cutting with the hammering , like I said I had no issues since .
Do you have a tune where you can adjust the shift pressure on the tranny ?
I lowered the pressure for the 1-2 shift with the xcal . I think it was too
aggressive but there was definitely clearance issue with mine.
Ohh I dropped the gas tank too , it sucks not having a lift
good luck !
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #30 of 33 (permalink) Old 03-11-2009, 03:29 PM Thread Starter
Maic's Avatar
Don't know where the issues come from. I just recently did the Rear end with new UCA, Spring Insulators, Compensator Link, new Knuckles, Air Bags and Diff. Bushings. Never noticed that before, the DS is in since approx. 4 years now.
So lets cut and Hammer, throw a Pinion brace in and hope for the best.
"cjchevez" no xcal here. SCT Chip and i don't think there is any aggressive about it.
Other than in your case, my noise only appears at mid. range takeoff and not at all in reverse.
-Maic
Maic.
Maic is offline
