auto tras fluid amount - TCCoA Forums
post #1 of 11 (permalink) Old 03-08-2009, 06:32 PM Thread Starter
POS Racing Team's Avatar
Send a message via AIM to POS Racing Team
doin my tranny tuesday, how much fluid do they take? autozone is closed and im not sure if they even know that **** and i couldnt find it on google. its a 95 4.6, so thats a 4r70w AOD, i think.
-1995 Thunder Bird
-4.6 V8 NPI
-Straight piped exhaust
-Jamex lowering springs 2 inches
-Shortened rear swear bar links
-Summit Underdrive pulleys
Slowly but surely
POS Racing Team is offline
post #2 of 11 (permalink) Old 03-08-2009, 06:36 PM
Buckcreekbilly's Avatar
14 qrts with torqe convertor and cooler.
Buckcreekbilly is offline
post #3 of 11 (permalink) Old 03-08-2009, 06:49 PM Thread Starter
i dont know a lot about trannys, i thought the torqe converter used different fluid? and how many quarts do you pun in the torqe converter?
-1995 Thunder Bird
-4.6 V8 NPI
Slowly but surely
post #4 of 11 (permalink) Old 03-08-2009, 07:19 PM
The entire sytem circulates the SAME fluid. Use only Mercon V fluid in this transmission.
post #5 of 11 (permalink) Old 03-08-2009, 07:32 PM
I hope your mechanic knows what he's doing, this isn't a project for the amateur do it yourselfer.
post #6 of 11 (permalink) Old 03-08-2009, 07:55 PM Thread Starter
yea, he does trannys all the time, i have no idea what im doing but i havent asked him any questions on how to do it. He works on Fox bodys and he has 5 of them and is a mechanic. I asked if he has done trannys and he said yea ive done a bunch.
-1995 Thunder Bird
-4.6 V8 NPI
Slowly but surely
post #7 of 11 (permalink) Old 03-08-2009, 08:52 PM
SuperNewbie
supergordo's Avatar
Changing your tranny fluid isn't too hard. It's not that hard or mysterious. It's just kind of messy. You have to make sure to drain the torque convertor as well as the tranny pan when you do it.
The transmission takes 12 quarts of fluid. Mercon V is the stuff to use, don't use any other type of fluid. If you have a tranny cooler you'll need a quart or two more of fluid depending on the cooler size.
When refilling it you need a nice long funnel to out into the trans dipstick tube. Start by filling 4 or 5 quarts into the car. Check for leaks, then start the car. Then slowly add 4 or 5 more. After that cycle the transmission thru the gears slowly (don't drive it yet). Then check the fluid level. Add more if it needs it. Take it for an easy drive thru your neighborhood(no racing) to cycle the fluid thru the tranny. Then Check the fluid again, add more if needed.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #8 of 11 (permalink) Old 03-08-2009, 10:16 PM
Lol, i didn't mean changing the fluid was hard, he's changing transmissions. Original thread led me to believe he was rebuilding transmission. We cleared that up thru pm's.
post #9 of 11 (permalink) Old 03-08-2009, 10:53 PM
SuperNewbie
supergordo's Avatar
Haha! Ok that makes a ton of sense now.
1995 Cougar XR7 4.6
post #10 of 11 (permalink) Old 03-08-2009, 11:57 PM
All in the verbiage. Lol
post #11 of 11 (permalink) Old 03-09-2009, 09:21 AM Thread Starter
thanks guys,
-1995 Thunder Bird
-4.6 V8 NPI
Slowly but surely
