Price of a j-mod - TCCoA Forums
post #1 of 17 (permalink) Old 04-01-2009, 07:43 PM Thread Starter
Price of a j-mod
How much would it cost to have a j-mod done to the transmisiion if you take it into a shop. Some guy on ebay who is selling his mark says he paid more than half of what he is asking for the car on the j-mod. So can it really be that he spent 1000 dollars to have a j-mod done to his transmission?
tino is offline
post #2 of 17 (permalink) Old 04-01-2009, 07:55 PM
For a simple jmod, if you replace accumulators and springs, including the 12 quarts of fluid if you also drain the torque converter and have to buy drill bits... not over a hundred bucks. Mercon V is usually 3-5 bucks a quart.
IF you could find a shop willing to do something like that, figure an hours labor, maybe 2, at 50-70 bucks an hour.
Bangster is offline
post #3 of 17 (permalink) Old 04-01-2009, 08:27 PM
Thumbs up
I got all my parts from ford and spent $92.59 that included new accumulators and servos, 1 spring,13 qrts of Mercon V,filter,gasket and 2 or 3 other things and did everything myself in about 4 hours I just followed instructions from this site best money ever spent ona modification.
96 4.6L CAT is offline
post #4 of 17 (permalink) Old 04-01-2009, 10:17 PM
terraplane8's Avatar
Mine cost me about $2500, but that's because I was an idiot and didn't put enough fluid in it. Fried my clutches, but not because of the J-mod itself. I'd already done it once before with my Mustang, but I got a bad case of stupid the second time around. Fortunately, my T-bird is a hobby car, not my daily driver that I depend on for everything.
Read the articles completely, get the right parts, don't overdo the HP levels, and take your time. It's easy, but if you've never even dropped a transmission pan, then now probably isn't the time to start unless you have some experienced assistance. Especially if this is your only car. I'd be leary of a shop doing it, unless you are 100% sure you can trust it. Good luck finding one that will, unless you live where there are a lot of Ford tuner shops.
Submariners do it deeper...
terraplane8 is offline
post #5 of 17 (permalink) Old 04-01-2009, 10:58 PM
VicRattlehead's Avatar
id expect over a grand for a complete jmodded trans. you guys are all talking just the valvebody mod. you guys do know theres 2 parts to it right? and last time i got mercon v i spent 150 for enough to fill my tranny
CMP Drag Racing
VicRattlehead is offline
post #6 of 17 (permalink) Old 04-02-2009, 10:05 AM
Mgino96tbird46's Avatar
I don't know, I don't think I could trust myself working on an automatic transmission on my only car that I drive everyday. Especially since I have very limited knowledge about automatic transmissions.
Mgino96tbird46 is offline
post #7 of 17 (permalink) Old 04-02-2009, 01:26 PM
Over 11 bucks per Qt . Yep the J-Mod is going to be my next MOD. That is one big expence for the job
post #8 of 17 (permalink) Old 04-02-2009, 04:34 PM
Looks like someone got ripped off!
post #9 of 17 (permalink) Old 04-02-2009, 04:49 PM
18 qts
CMP Drag Racing
post #10 of 17 (permalink) Old 04-02-2009, 10:08 PM
The Band, not the Disease!
AnthraxBird's Avatar
An if you buy Merc. V.. for the love of god please dont buy Coastal or any other cheap merc V... it's GARBAGE! Plan on spending 100 or so plus for good fluid. Remember if you add an aux cooler, it will require more fluid.. and when topping it off, make sure your on LEVEL ground and the engine is RUNNING in park, and at NORMAL operating temperature.
AnthraxBird is offline
post #11 of 17 (permalink) Old 04-03-2009, 12:09 AM
Buckcreekbilly's Avatar
I bought my Mercon from a Ford dealer and it was cheaper than Napa etc. Couldn't believe it, in Canada and i paid $114.37C for 14 qrts.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #12 of 17 (permalink) Old 04-03-2009, 06:14 AM
id expect over a grand for a complete jmodded trans. you guys are all talking just the valvebody mod. you guys do know theres 2 parts to it right? and last time i got Mercon v i spent 150 for enough to fill my tranny
Over 11 bucks per Qt . Yep the J-Mod is going to be my next MOD. That is one big expense for the job
18 qts
150 / 18 equals over $8 a quart. Still to much IMO.
post #13 of 17 (permalink) Old 04-03-2009, 12:47 PM
yea so.
CMP Drag Racing
post #14 of 17 (permalink) Old 04-03-2009, 05:16 PM
96tbirdboi's Avatar
whats a j-mod(noob)
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #15 of 17 (permalink) Old 04-03-2009, 05:20 PM
Originally Posted by 96tbirdboi View Post
whats a j-mod(noob)
Basically, it's a shift kit that one of the guys who implimented the 4R70W wrote up to help us get the most out of our transmissions. One of the best mods for any MN12 or ANY 4R70W to do and will help increase the life of the unit.
post #16 of 17 (permalink) Old 04-03-2009, 06:14 PM
96tbirdboi's Avatar
where can i get one and what price
Comp 262 cams
Sport springs
Steeda UDPs
post #17 of 17 (permalink) Old 04-03-2009, 06:31 PM
RobertP
Carolinas Crew Chief
http://www.robstireandauto.com/index.html
