Fluid change??? - TCCoA Forums
post #1 of 10 (permalink) Old 07-20-2009, 12:50 AM Thread Starter
mh68's Avatar
Fluid change???
My 95 bird does the slight shudder sometimes when shifting into 4th, not very often, but it does it. It has around 165,000 miles on it and I'm wondering if the old wives tale is true if I change the fluid on a high mileage car that hasn't had regular trans service, my trans will start slipping afterwards. The fluid is still red and smells normal too. I want to flush it and fill with mercon V but want to make sure it won't cause a problem.
Mike
mh68 is offline
post #2 of 10 (permalink) Old 07-20-2009, 01:09 AM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
I changed mine at 136,xxx and the Mercon V actually fixed most of my problems.
Check around here in the forums, there are plenty of threads about the exact question you asked, and there are tons of answer's.
Take this thread for example. problems with late tranny fluid change?
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #3 of 10 (permalink) Old 07-20-2009, 09:08 AM
Buckcreekbilly's Avatar
Did it on my 95 and it worked wonders, shudder went away totally. I would also recommend the jmod while your at it.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 10 (permalink) Old 07-20-2009, 10:00 AM
chris g's Avatar
Send a message via Yahoo to chris g
sorry to jump in with a question, what if u've changed the fluid to mercron v and it still shudders?
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #5 of 10 (permalink) Old 07-20-2009, 08:58 PM
chris g's Avatar
jus figured i'd ask?
chris g is offline
post #6 of 10 (permalink) Old 07-20-2009, 09:34 PM
New torque converter, most likely.
I'd check the contamination level before putting in a new converter, tho. If you think you may be doing a transmission soon, do both at the same time, and flush the cooler very well.
post #7 of 10 (permalink) Old 07-21-2009, 01:28 AM
Briglad's Avatar
I had very good luck with my 94. Had about 120,000 on it and had a slight shudder. The fluid was the color of hot fudge...
The shop that does most of my work, did a complete flush, new filter, etc. It was like I put in a new transmission. Car still shifted great when it went to the scrappers because it was too rusty to pass inspection.
Brian
Current Ride: 97 Bird LX 4.6 Lawn ornament / Past Rides: 94 Bird LX 4.6 / 94 SHO / 86 bird 3.8 / 77 Ranchero GT 400M / Also many, many Rangers, a Tempo, a Sable and a pair of Windstars.
Briglad is offline
post #8 of 10 (permalink) Old 07-21-2009, 01:46 AM Thread Starter
mh68's Avatar
Sounds like I'm going to be doing a flush then
Mike
mh68 is offline
post #9 of 10 (permalink) Old 09-13-2009, 01:50 PM
If you haven't gotten to it yet try SeaFoam Trans Tune. Worked wonders on my '96 LX (124K miles and fluid never changed) . I also had a slight stutter and hard shifts. Now I can't feel the trans shifting.
Red
Panamah_red is offline
post #10 of 10 (permalink) Old 09-13-2009, 07:32 PM Thread Starter
mh68's Avatar
Mike
Just an update on my trans. I got it flushed and the new fluid in and not one shudder yet and it's been a month now!
Mike
mh68 is offline
