thunderbird rear end swap... an unusual item here.. - TCCoA Forums
post #1 of 3 (permalink) Old 09-30-2009, 07:33 PM Thread Starter
Banned
Question thunderbird rear end swap... an unusual item here..
has anyone made the changeover from an irs to a solid axle, as in the ford 9 inch, on an mn12 body without having to use a plasma cutter and torch on the entire floorpan?
It sounds unusual to want to go from an IRS to a solid axle setup I know, but it has been done on cars like the cobras and I am curious as to what all would be involved.
I ask because eventually this car will be making passes at the local 1/8th mile track and I want it bulletproof and rock solid dependable for the trips over and back. (48 miles each way).
I plan to goto 3.73 gears in the rear end I have now plus already have those gears installed into whichever rear end I have installed, whether it be a solid axle 8.8 or the ford 9" unit.
remember now, a bit of a newbie on these cars but I am not completely stupid about cars all together.
one other thing, this car suffers from peg leg syndrome... can I put the standard 8.8 from a car like a mustang into it without doing a bunch of pain in the butt work to get it right? what all do I need? I know where a guy has an 8.8 center section that he got from me, providing he hasnt sold it or used it yet.
let me know some solid answers so I can start figuring this stuff out..
thanks a bunch
Big Ed H is offline
post #2 of 3 (permalink) Old 09-30-2009, 07:51 PM
thanks a bunch
post #3 of 3 (permalink) Old 09-30-2009, 10:24 PM
No, its a giant fabrication project and the only cars that do have it are completely back halfed.
Cobras are mustangs, the platform is designed for a solid axle, Its a direct bolt in. These arent even close to mustangs, they were only ever intended to use an IRS
Theres big power mn12's doing just fine on IRS, what kind of power do you have and what drivetrain setup are you using?
If you remove the circlips from the halfshafts you can use the mustang trac-lok carrier, however I recommend using an IRS part.
thanks a bunch
