how much longer till.......*pow* nottin - TCCoA Forums
post #1 of 25 (permalink) Old 04-03-2010, 06:06 PM Thread Starter
earlier today in a span of only 15 mins my trans slipped 4 times. that to me seems to alot for a trans to slip in that short of a time. i checked the fluid bout a week ago andit wasd fine so it should still be fine. im not leaking any fluid, so im not sure whats goin on. im sure this has been discussed, but i couldnt find anything to help me out. ive found anouther 94 4r70w trans with 70,000 miles on it. if i get that trans what else should i grab? grabing the engine would be nice, but mine is running fine so wouldnt need to do that.
hershy314 is offline
post #2 of 25 (permalink) Old 04-03-2010, 06:20 PM
a newer Torque converter 94s are junk
post #3 of 25 (permalink) Old 04-03-2010, 07:13 PM Thread Starter
like what year or like one from b&m or something?
post #4 of 25 (permalink) Old 04-03-2010, 07:44 PM
Earl's Avatar
dirtydog converters are good from what i hear....id you are going to change out the trans get a 98 or newer 4r70w or buy a built trans from somebody like lonnie at blueovalchips.....but before you do that try a fluid filter swap with mercon v and a new filter and clean the magnet in the trns...
Earl is offline
post #5 of 25 (permalink) Old 04-03-2010, 08:25 PM Thread Starter
i do have a filter that i just got. some reason i didnt get an fluid. how much fluid should i get?
post #6 of 25 (permalink) Old 04-03-2010, 08:37 PM
Earl's Avatar
i dont know off hand....i'm sure it's been mentioned here before...maybe it says in the manual
Earl is offline
post #7 of 25 (permalink) Old 04-04-2010, 12:26 AM Thread Starter
hopefully i can out sooner or later, so far ive found nottin
post #8 of 25 (permalink) Old 04-04-2010, 02:14 AM
13 quarts, 14 if you have an aftermarket cooler installed (which is recommended btw).
post #9 of 25 (permalink) Old 04-04-2010, 02:16 AM Thread Starter
thanks and i am considering getting one.
post #10 of 25 (permalink) Old 04-07-2010, 08:36 PM Thread Starter
finally got around to changing the trans filter, what a pain in my butt. i dont know if it helped or not, didnt get all the bolts in before the rain hit. (sucks not having enough garage space). hopefuly il have it back on the road and no more slipping. ill post an update tomorrow
post #11 of 25 (permalink) Old 04-07-2010, 08:59 PM
Earl is a huge believer in the change fluid and filter fix after I fixed his old car that way. Fresh mercon v is great stuff for these trannys. Preventative maintenance is a must on these cars.
post #12 of 25 (permalink) Old 04-07-2010, 09:40 PM Thread Starter
i totally agree, wish the previous owner did that. i do have one problem tho. how do i get those bolts in that go between the ebrake and the trans?
post #13 of 25 (permalink) Old 04-08-2010, 12:37 AM
Earl's Avatar
my trans has developed a leak...shifts fine but I have to watch the level like crazy and it runs hot...gonna do a flush/filter/add a cooler and I think it's a leaking line or something because it seems like it's leaking up by the radiator....it's always something...how's the old bird doing anyway?
Earl is offline
post #14 of 25 (permalink) Old 04-08-2010, 05:36 AM
It's doing well. Still waiting on money before paint, but the pi heads, intake manifold, cams, headers, and other goodies are all set aside waiting to go on.
post #15 of 25 (permalink) Old 04-08-2010, 03:48 PM Thread Starter
new filter and fresh fluid works great, no more slipage and the car runs really smooth now. its great.
post #16 of 25 (permalink) Old 04-08-2010, 07:13 PM
sousa632's Avatar
I feel the same way. My trans had a chattering when I put it in drive or reverse and it would slip some after the 3rd gear change when warm(fluid and filter had about 55K on it). Drained all the fluid and tq converter, replaced the filter and put in Mercon V and the trans is very nice now. Maintenance is most definately the key here.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #17 of 25 (permalink) Old 04-08-2010, 07:28 PM Thread Starter
well i thought that fixed my problem. just a little while ago i went to go get dinner, when i left i had no problems. but coming back the car didnt want to shift out of first gear.
post #18 of 25 (permalink) Old 04-09-2010, 12:19 AM Thread Starter
any ideas?
post #19 of 25 (permalink) Old 04-09-2010, 04:47 AM
Earl's Avatar
headers? what headers? what brand? that's something I'd really like to do on this one when I do the 2.5 true dual / x pipe exhaust...is it still muffler-less? If so, you gonna add mufflers to it? I'm thinking of doing dynomax racebullits on my next true dual setup...for the 96 oh, and the 96 just might have a set of ported worked over PI heads coming it's way
Earl is offline
post #20 of 25 (permalink) Old 04-09-2010, 07:23 PM Thread Starter
now the trans is leaking, the fun never ends!
post #21 of 25 (permalink) Old 04-09-2010, 08:16 PM
Sounds like the car ran great full of fluid. Now you discover it's been leaking. Makes sense to me it leaked until it's low enough not to shift right.
1) Go to one of those high-pressure car washes, spray degreaser around engine, tranny, under car, etc.
2) Rinse with hi-pressure water until clean.
3) Drive home.
4) Look where fresh leak is coming from.
5) Repair leak.
6) Enjoy!
post #22 of 25 (permalink) Old 04-09-2010, 09:08 PM Thread Starter
i have a feeling i know where the leak is
post #23 of 25 (permalink) Old 04-10-2010, 04:58 PM Thread Starter
fixed.....i hope
post #24 of 25 (permalink) Old 04-10-2010, 09:28 PM
sousa632's Avatar
Was the pan not torqued down properly?
John
1996 TBird LX 4.6
sousa632 is offline
post #25 of 25 (permalink) Old 04-10-2010, 09:46 PM Thread Starter
yep that was it
