aod into a 4r mn12 - TCCoA Forums
post #1 of 10 (permalink) Old 04-20-2011, 03:13 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
aod into a 4r mn12
before we get into the aod vs 4r pissing match, i have a built aod sitting in storage that will be going into the 95. my current 4r has water in it, so its going south.
disregard the eec/wiring issue for now. what has to be done to get the aod to work?
i believe i need to use the aod driveshaft and tranny mount bracket.
i assume i will ditch the 4r throttle/cruise cables and use the aod ones.
how will i get the 4r shifter to work with the aod?
what else am i missing?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 10 (permalink) Old 04-20-2011, 05:11 PM
Problem #1 you have to make it bolt up, you can use an early 4.6 block.
post #3 of 10 (permalink) Old 04-20-2011, 05:51 PM
davis97xr7's Avatar
Shouldn't be a problem if he's bolting the AOD up to a 3.8, should it?
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #4 of 10 (permalink) Old 04-20-2011, 06:28 PM
Dunno why I was thinking 4.6, on a 3.8 it will bolt on, flexplate is fine too. the important piece of the puzzle is the tv cable parts, just put the 4r extension housing on and use the 4r driveshaft. TV cable is critical, if you get it wrong your aod will become a paperweight quickly.
post #5 of 10 (permalink) Old 04-21-2011, 01:08 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
same thing as the tailshaft housing? it will bolt onto the aod case? interesting.
how about getting the shifter to function?
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 10 (permalink) Old 04-21-2011, 02:48 PM
Or just run a driveshaft for a 89-93 AOD MN12. The engine mounting locations didn't change from 93-94 so if you run the regular length AOD, the stock 89-93 driveshaft will be the right length.
post #7 of 10 (permalink) Old 04-21-2011, 03:11 PM
I don't know what you will have to do with the shifter, it may work as is. The driveshaft I would just change the housing, you get better stuff and don't have to buy anything at all.
post #8 of 10 (permalink) Old 04-21-2011, 04:40 PM
bowez's Avatar
Wouldn't a constant pressure or manual valve body remove the TV issue?
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #9 of 10 (permalink) Old 04-21-2011, 05:31 PM
Yes, but isn't the idea of this to do it inexpensively? if money is not the issue fix the 4r.
post #10 of 10 (permalink) Old 04-21-2011, 06:35 PM
bowez's Avatar
Well then need brackets form a MN-12 (tranny and TB) for the TV and the cable. Assume get them all at pull-a-part. Though they may be a bit hard to come by since Dan(silverfox) doesn't even have them
93 SC Tbird
93 5.0 Tbird
bowez is offline
