need rear end lube recommendations :) - TCCoA Forums
post #1 of 9 (permalink) Old 11-23-2011, 05:31 AM Thread Starter
coggonobrien's Avatar
alright pull your minds out of the gutter what do you all recommend for pumpkin oil? i've got a track lok and 4.10's in my pumpkin, had conventional oil plus limited slip modifier in it. i'm swapping the pumpkin to a differant car so I figured it's a good time for fresh oil. also how much do I need.
David
coggonobrien is offline
post #2 of 9 (permalink) Old 11-23-2011, 07:58 AM
The Ford service manual specifies this lube http://www.sarad.com/productinfo.aspx?p=238330 with the friction modifier.
I'd probably use the Valvoline 85W90 with the friction modifier built in. That, or Royal Purple. If Dirtyd0g pipes up with a better choice, use his recommendation instead.
As to "how much", from bone dry the trac lok diffs use 1.5 litres, 3.25 pints, not quite 2 quarts.
I'd buy two quarts, and fill to the proper level.
RalphP is offline
post #3 of 9 (permalink) Old 11-23-2011, 09:56 AM
Our experience has been if you can't get some lube with the modifier already included (a lot do), then GM modifier has worked best; use as little as possible (of the modifier, make sure you put the correct amount of oil in the pumpkin).
~Rick
TCCoA Sig
post #4 of 9 (permalink) Old 11-23-2011, 12:08 PM Thread Starter
Which royal purple they don't make 85 90
post #5 of 9 (permalink) Old 11-23-2011, 12:50 PM
For break in use 2 bottles of ford friction modifier and 2 quarts of cheap 75-80w90. Once broke in use the motorcraft 75w140 gear oil.
post #6 of 9 (permalink) Old 11-23-2011, 01:11 PM Thread Starter
so no friction modifier when broke in?
post #7 of 9 (permalink) Old 11-23-2011, 01:32 PM
The expensive fluid has it in it already.
post #8 of 9 (permalink) Old 11-23-2011, 05:23 PM
If they don't, then don't use it.
I'm running Valvoline because a) it's not that much and b) it includes the friction modifier. And I have a pinion seal leak.
RalphP is offline
post #9 of 9 (permalink) Old 11-23-2011, 06:09 PM
That's because Royal Purple is synthetic, 85w90 is not. I think the RP bottle says 75w90 on it. Synthetics are always wider weight range because of the superior properties to natural oils.
~Rick
TCCoA Sig
