Aluminum drive shaft?? - TCCoA Forums
post #1 of 10 (permalink) Old 10-24-2012, 09:27 PM Thread Starter
WildBill4point6's Avatar
Send a message via Yahoo to WildBill4point6
Went to the local yard to get some odds n ends from the 3 thunderbirds they have, and i had to walk across 4-5 mark 8's was wondering if the aluminum driveshaft would be a direct replacement for my 97 4.6?
-Harrison
1996 Blue 4.6 ThunderBird
WildBill4point6 is offline
post #2 of 10 (permalink) Old 10-24-2012, 10:11 PM
REDWOLF5952's Avatar
only a 93 mark 8 has a solid alum drive shaft which is a direct replacement
Mods: ECU tuned by Clintd for 93 octane, J-mod and PI intake(PI heads soon).
-Im the only Wolf among these dogs-
REDWOLF5952 is offline
post #3 of 10 (permalink) Old 10-24-2012, 10:11 PM
Yes, but the preferred driveshaft is the 1993 Mark VIII that doesn't have the rubber vibration elimination joint near the rear joint.
~Rick
TCCoA Sig
post #4 of 10 (permalink) Old 10-24-2012, 11:07 PM Thread Starter
Good to kno. Doing a vehicle inventory right now. Any other parts I could / should salvage from.the mark 8?
-Harrison
post #5 of 10 (permalink) Old 10-24-2012, 11:11 PM
I swapped the whole rear sub-frame from a Mark VIII into my Bird and saved over 50 lbs of weight; the LCA's and the pumpkin on the Mark VIII are aluminum.
~Rick
TCCoA Sig
post #6 of 10 (permalink) Old 10-24-2012, 11:16 PM
Robe's Avatar
You could also grab the rear lower control arms and differential out of the marks they are aluminum.
Robe is offline
post #7 of 10 (permalink) Old 10-24-2012, 11:17 PM Thread Starter
Wow. Ya just looked online its a 97, the other loncolns must have been continentals. They have 4.
-Harrison
post #8 of 10 (permalink) Old 10-24-2012, 11:26 PM
My rear end came out of a 98 Mark VIII LSC:
~Rick
TCCoA Sig
post #9 of 10 (permalink) Old 10-25-2012, 12:13 AM Thread Starter
wow now that is awesome...dare i ask how hard it is to change all that over?
-Harrison
post #10 of 10 (permalink) Old 10-25-2012, 11:43 AM
I used these:
Here is the thread about it: http://forums.tccoa.com/showthread.php?t=127192
~Rick
TCCoA Sig
