two questions... - TCCoA Forums
post #1 of 10 (permalink) Old 12-22-2012, 09:42 PM Thread Starter
two questions...
I found a rebuilt aod transmission... I know it bolts in.... I have a 94 and I'm unsure what year mustang they had if I ran a 93-92 ecu will I bypass the issues? I also found a few 2001-2003 4.6 4rw70... what is repinning??? I have already killed the super coupe tranny :/
tee-bird is offline
post #2 of 10 (permalink) Old 12-22-2012, 10:20 PM
So you want to convert a 94 from a 4R70W to an AOD?
The bellhousing bolt pattern is different between a 3.8 and a 4.6.
To repin the connector means to release the pins and put them in a different place.
Bangster is offline
post #3 of 10 (permalink) Old 12-22-2012, 10:31 PM
Moderator & Teksid Whore
guitar maestro's Avatar
don't waste your money. Pick up a refreshed 99+ 4R70W from either RobertP or DirtyD0g.
guitar maestro is offline
post #4 of 10 (permalink) Old 12-23-2012, 08:49 AM Thread Starter
Well I have two bell housings off 3.8's that wouldn't be a big deal? To swap our.
tee-bird is offline
post #5 of 10 (permalink) Old 12-23-2012, 10:59 AM
The bell housing is integral with the transmission case.
You mean you have a 4R70W case with the SBF bellhousing bolt pattern, and want to transfer the internals of a mod motor transmission to the correct case?
Bangster is offline
post #6 of 10 (permalink) Old 12-23-2012, 03:35 PM
You can use a 4r70w off any v6 mustang (I saw a 2004 at the yard last week) that should have the correct bell housing. That is A LOT easier than transferring internals !!!
Repinning just means moving some of the wires around in the plug that goes into your transmission.
You're going to have to use all the solenoids from your old transmission.
~Rick
TCCoA Sig
post #7 of 10 (permalink) Old 12-23-2012, 08:34 PM Thread Starter
Thanks rick!. I found a low mileage 03 and a fair mileage 96.... all under 100$... I debated on waiting till I have 500$ I found a supercoupe completely and said I could have everything they will pull it 500$ minus the drive shaft because the forklift the cars.... so its dented... I might go that route... I have done two maunal conversion on a saturn and a cavalier...
tee-bird is offline
post #8 of 10 (permalink) Old 12-23-2012, 08:49 PM
If that '03 low-mileage 4R70W is from a v6-equipped car and you can get it for under $100, SCORE!
~Rick
TCCoA Sig
post #9 of 10 (permalink) Old 01-26-2013, 07:37 AM Thread Starter
so reuse my shift sloniods and tcc? and rewire it? thats it.. i have a 01 transmission sitting here...
tee-bird is offline
post #10 of 10 (permalink) Old 01-26-2013, 04:52 PM Thread Starter
Last set of questions on 2001+ trans
Ok.. I got the 2001+ trans bolted the VSS spot was blocked off with a yellow tab and a o-ring... Pulled it felt nothing.. "really don't care if i have a Speedo" i can use GPS for this.... My point is will this effect the shifting or what not? i didn't feel any splines on the output shaft.. but i went ahead and put my vss in. I have torn the pan off got down to this...
I don't get how to take it apart? with out snapping anything.. any light?
I have the old TCC and Shift sitting on the new transmission
Why can't i just use this old wiring harness? it came out easy? that would mean i wouldn't have to repin??? i still have the other harness if not... can i cut and splice that way?
Basicly i need to know with out the speedo working it should still shift either way... and of course the other questions i have asked.... Much help would get this bird on the road......
tee-bird is offline
