Traction control question - TCCoA Forums
post #1 of 15 (permalink) Old 03-25-2013, 12:59 PM Thread Starter
TwoHaggard's Avatar
My car has traction control and has the switch that you have to switch off on the VMM every start up, well my ABS sensor is broke on my front spindle so now that switch does not want to work, is there a way I can wire the switch together or something to turn traction control off without a tune. Thanks
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is online now
post #2 of 15 (permalink) Old 03-25-2013, 01:04 PM
95LX4.6's Avatar
I don't really have the time to do a search for ya right now, but I know of at least one thread here on the site that has the TC permanantly shut off. Hope it helps and good luck with the search.
95LX4.6 is offline
post #3 of 15 (permalink) Old 03-25-2013, 01:07 PM
There's no communication network between modules on these cars so no, a tune won't disable it.
If there's a fault with an abs sensor like you describe the abs system may have disabled itself ergo disabling T/A, which won't send out the "off" signal to the VMM
post #4 of 15 (permalink) Old 03-25-2013, 04:53 PM Thread Starter
TwoHaggard's Avatar
Ok but even after I fix that ABS sensor is there a way to wire the switch so I wouldn't have to shut it off every start up
post #5 of 15 (permalink) Old 03-25-2013, 04:55 PM
95LX4.6's Avatar
Refer to above post
95LX4.6 is offline
post #6 of 15 (permalink) Old 03-25-2013, 05:19 PM
Jump the switch closed.
If ABS is disabled due to a fault then T/A is also disabled since it relies on ABS to operate.
post #7 of 15 (permalink) Old 03-25-2013, 06:39 PM
rushtonracing's Avatar
Here is a schematic of the Teves Mark IV abs system with Traction Assist (TRACS).
It seems to me a simple latch (toggle) switch located at circuit 298 P/O after the 5 amp. fuse would turn the TRACS off at all times when the switch is held in the open position, (pin #25 of the Control Module is the switch for TRACS). Said switch would also keep the TRACS "Off" indicator light non-illuminated.
I think the factory switch does the same thing, but supplies a ground, or power, not sure which, to illuminate the TRACS Off light, and closes the circuit every time the ignition switch cycles from Run to Off and back to Run.
In both cases the ABS should not be affected.
I've never actually installed such a switch so I could be in error. What do y'all think? Would this work?
rushtonracing is offline
post #8 of 15 (permalink) Old 03-25-2013, 07:50 PM
298 is power for the whole VMM(and several other devices just after the fuse. Putting a toggle on it will effectly shut all the other indicator lights off.
post #9 of 15 (permalink) Old 03-25-2013, 09:02 PM
Perhaps then at circuit 959? Or do those other devices complete their circuit through pin #25 of the ABS Control Module?
Forgive me, but this seems counterintuitive. The switch on the dash is designed to work...ah..."backwards"? Please don't get me wrong. I am not attempting to be argumentative. I'm simply in a process of learning this system better, and would greatly appreciate any more knowledge you have on how/why closing the circuit would disable the TA.
post #10 of 15 (permalink) Old 03-25-2013, 11:44 PM
It needs to be jumped as Brandon said. Cutting circuits won't do anything as the abs module itself is what determines if it's on or off.
The diagrams are slightly misleading as the T/A switch is not a toggle switch as it appears but a momentary switch. Pressing the switch sends a input(12v) to the ABS Module to disable or enable Traction assist, hence why it wouldn't work for twohaggard under failure mode. It was seeing the signal just fine but under a fault condition it won't send actuated outputs to the anything but the ABS warning light in the cluster.
When you start the car up, the module is designed go through a quick cycle and default T/A to "on". When the switch is held closed through that cycle however, the module will turn it off. That's just the way the module is programmed. Remember, you're not directly opening or closing the circuit when you press that switch, you're just sending a binary signal to the module.
post #11 of 15 (permalink) Old 03-25-2013, 11:44 PM
skinnytick's Avatar
skinnytick is offline
post #12 of 15 (permalink) Old 03-26-2013, 06:32 AM
Thank you Matt for the explanation. That makes sense to me now. And thank you skinnytick for the link, and those pics. Knowledge is really priceless, and folks such as yourselves give TCCoA a heart of gold.
post #13 of 15 (permalink) Old 03-26-2013, 07:47 AM Thread Starter
TwoHaggard's Avatar
In the pictures it looks like there jumping gray an blue/red but if I'm reading that diagram right it says gray and black/ light blue ??
post #14 of 15 (permalink) Old 03-26-2013, 01:42 PM
Jump Grey and Purple/Orange. (I think your monitor needs adjustment if it looks blue and red in the pic lol)
The module needs to see a voltage signal, jumping the bulb trigger(BK/LB) with the input(GY) won't do anything.
post #15 of 15 (permalink) Old 03-26-2013, 03:17 PM
skinnytick's Avatar
Yep, it's purple/orange stripe.
Plug the harness back into the VMM to verify the traction is now off, then pull the bulb.
