A4ld Trans?? - TCCoA Forums
post #1 of 5 (permalink) Old 03-31-2013, 11:37 AM Thread Starter
chris g's Avatar
Send a message via Yahoo to chris g
A4ld Trans??
92 ranger is full of fluid but will only try to move when you put it in gear.. whether its forward or reverse. i was told its the front pump.
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #2 of 5 (permalink) Old 03-31-2013, 12:57 PM
slick59's Avatar
probably so. I had one in my Bronco II. those tranny's are a piece of junk.
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
post #3 of 5 (permalink) Old 03-31-2013, 02:47 PM
97 30th's Avatar
X2 Had one in my 89 Ranger JUNK
You can't fix stupid
97 30th is offline
post #4 of 5 (permalink) Old 04-04-2013, 09:10 PM
nall_one's Avatar
only problems we ever had with our 93 ranger was the bell-housing warped, offsetting the convertor in the pump seal and dumping tons of fluid under load. otherwise just driving around she was fine with 31/10.50r15's for 200k+ with regular fluid changes.
wouldn't say its junk, but i wouldn't ever want to own one again either
the lower millage explorer power-train we swapped in has the same problem i guess its a service bulletin as well.
nall_one is offline
post #5 of 5 (permalink) Old 05-10-2013, 01:07 PM
BIRDMANLX281's Avatar
i talked to a friend of mine and he said its either the front pump or torque converter.. anybody got any ideas??
lowered 1.5'' with vogtlands,, tokico ''blues'' on all 4 corners... 28% mirror tinted windows,, P.I.Intake swapped,, S.C side skirts and rear bumper..
BIRDMANLX281 is offline
