Trunk Monkey's Axles - TCCoA Forums
post #1 of 34 (permalink) Old 10-31-2013, 08:16 AM Thread Starter
ricky05uphs's Avatar
... Almost twisted off lol
95 4.6 Bird full PI swap daily driver, DD 2200 stall converter, Jerry chip, 80mm Maf.
Back in the day with a few other mods such as 3.73 (3.08's now), underdrive pullies(back to stock pullies now)and C&L upper and 70mm TB. [email protected]
96 Tbird FRPP/SVO blower 3.3 pulley, 70mm TB, 90mm maf, AIS w/2 nozzles,iron block with -3cc dish mark VIII pistons, stock pi heads/cams , DD 3800 stall converter, Built trans by Robertp, ported manifolds, nice exhaust, Cobra rearend with 3.73's, Mach 1 Breaks up front, SCT tuned by Robertp, and 60lbs injectors and 405lph pump. E85
2005 expedition 5.4 family vehicle
ricky05uphs is offline
post #2 of 34 (permalink) Old 10-31-2013, 09:10 AM
Hum, I should check mine then.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #3 of 34 (permalink) Old 10-31-2013, 10:42 AM
CDsDontBurn's Avatar
Too much time at the drag strip?
CDsDontBurn is offline
post #4 of 34 (permalink) Old 10-31-2013, 11:40 AM
To much power and hard tires
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #5 of 34 (permalink) Old 10-31-2013, 06:28 PM
Are those his stock 1995 LX axles?
~Rick
TCCoA Sig
post #6 of 34 (permalink) Old 10-31-2013, 07:44 PM Thread Starter
They are stock.
post #7 of 34 (permalink) Old 10-31-2013, 07:49 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Need I say more?? LOL
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #8 of 34 (permalink) Old 10-31-2013, 08:26 PM
Moderator & Teksid Whore
guitar maestro's Avatar
send them to me....I'll force 200A DC and some filler rod with the TIG and they'll be like new.
guitar maestro is offline
post #9 of 34 (permalink) Old 10-31-2013, 09:04 PM
33 spline axles will do the trick
10.75 @128.38
RobertP is offline
post #10 of 34 (permalink) Old 11-01-2013, 10:17 AM
r429460's Avatar
I'm going to test my new ones tonight.
I had to buy a new torque wrench to install them right.
Rob, is that thing taken care of?
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #11 of 34 (permalink) Old 11-01-2013, 04:35 PM
We'll I have proof of delivery so that's perfect
10.75 @128.38
RobertP is offline
post #12 of 34 (permalink) Old 11-01-2013, 04:54 PM
Awesome catch; that would be bad if it breaks under power.
You caught it at exactly the right time; it's stronger after the first yield, but much, much more fragile.
Cut a section out of the broken area, polish it, and hit it with a mild nitric acid solution; that will bring up the grain so you can see it easily.
Vinegar will work in a pinch, but it won't look as good.
(Torn metal looks like a sponge under the microscope, if you've never seen it.)
It's amazing how much energy it takes to do that.
TM, I'd make that a desk ornament, considering your career.
"This is what it looks like just before it breaks..."
post #13 of 34 (permalink) Old 11-01-2013, 05:02 PM
Yea, I've done acid etching before. It does look cool.
Yea it takes a tremendous amount of force to tear metal like that.
You're right. That would make a great desk ornament. I would like to PT or MT those to see what else is there that you can't see with just a VI.
Save those for me Rob. I meant to ask you sooner but I'm sure you'll just throw them in a pile somewhere in the shop until you're ready to make another scrap run or did you send them to DSS to rebuild?
post #14 of 34 (permalink) Old 11-01-2013, 05:13 PM
Parts had to go to dss
10.75 @128.38
RobertP is offline
post #15 of 34 (permalink) Old 11-01-2013, 05:28 PM
Yeah yeah yeah, we get it, your car is powerful. You don't need to emphasize words reenforcing it
post #16 of 34 (permalink) Old 11-01-2013, 07:42 PM
You guys do some testing that is amazing in what it sees.
(I wanted to post a paragraph here, but I really can't, my Corp would not approve...)
The metal etching I do these days is all copper, looking for bad thru-hole vias.
The ruined metal will look foamed, stretched into a form that held, lol.
But, that doesn't mean it will hold in a different direction; a hard bump could have really worked those.
It likely would have been little cones sticking out of the hub, with a little tear where it let go.
BTW, Rob: Credit where Credit is due, Son!
You built that Sh*t; walk proud, man!
I see why you upgraded.
post #17 of 34 (permalink) Old 11-01-2013, 09:09 PM
I wanna see a lot of good pics of the new ones! Those damn wheel hops are what kills everything. I'm hoping the slicks will keep that from happening to save my new (but stock) half shafts. Otherwise I will have to step it up and beat everyone with some customs made 300M billet steel axles
post #18 of 34 (permalink) Old 11-01-2013, 09:53 PM
These new one are 300m shafts and 4340 outlets
Ron I've got the inner with the cracks, my briber said he can redrill hubs just gotta get pricing from him but either way it has to be done
10.75 @128.38
RobertP is offline
post #19 of 34 (permalink) Old 11-01-2013, 09:58 PM
So is the hub bore on the wheels in the Mustang size or the Tbird size?
post #20 of 34 (permalink) Old 11-01-2013, 10:18 PM
1MTNCAT's Avatar
The slicks, Better rear bushings, Air lift bags will all help control that. But you are correct, stiff sidewall tires and bounce along with the power is what snaps them most often. The softer sidewalls on the large sidewall slicks do help absorb some of the shock, therefore less bounce. Regardless I've broken them both ways and the last time as a set at once.
So it can be done.
Steve
1MTNCAT is offline
post #21 of 34 (permalink) Old 11-01-2013, 10:25 PM
There mustang lug pattern so we gotta have them drilled to tbird hub pattern and prolly open up the center of rotor
10.75 @128.38
RobertP is offline
post #22 of 34 (permalink) Old 11-02-2013, 07:41 AM
Yea, yea, ... You know, I hadn't even thought of it as bragging. Like Grog6, I was more impressed by the forces involved that it takes to do that to steel (regardless of source) than implying that my car is some kind of HP monster. There are certaily many other cars here that make a lot more HP and run a lot faster than mine does.
Rob and others here have snapped them clean. My car only makes enough power to crack them.
post #23 of 34 (permalink) Old 11-02-2013, 10:04 AM
1MTNCAT's Avatar
BS, the car makes plenty of power to break them. It just hasn't hooked good enough yet to make it happen. Luckily with the new CV Axles you won't get the opportunity to do it. Like I said before, you were on borrowed time but that has been corrected.
Good luck with her TM!!!!!
Steve
1MTNCAT is offline
post #24 of 34 (permalink) Old 11-02-2013, 10:08 AM
Thanks Steve,
You need to come back down to Fayetteville again this year and vouch for my new time.
Although I expect it'll be fast enough to get me booted from the MAMN12 DRT list...
Hope to see you there!
post #25 of 34 (permalink) Old 11-02-2013, 11:17 AM
1MTNCAT's Avatar
Its not looking good at this point in that happening.
I don't even know if Chris is going down. Plus I'm right in the middle of hunting season at that point and I need to make a trip to pick up a Christmas present.
But as always, good luck on your drag days!
Steve
1MTNCAT is offline
post #26 of 34 (permalink) Old 11-02-2013, 11:33 AM
Thanks.
Happy hunting!
What's the score so far this year? Is lady MTNCAT beating you kill count yet?
post #27 of 34 (permalink) Old 11-02-2013, 12:01 PM
I agree; a bit more traction and this would be a "Look what I broke!" story instead.
Awesome work, Guys!
It ain't easy getting that kind of power thru our setup.
post #28 of 34 (permalink) Old 11-02-2013, 12:34 PM
So that makes your car a track crack whore....you know... 'cause it cracks things....at tracks
post #29 of 34 (permalink) Old 11-02-2013, 04:38 PM
Hey, now; a Track Ho that can Bend it, twist it, but not break it has my respect.
And Friend request, lol.
post #30 of 34 (permalink) Old 11-02-2013, 06:30 PM
LOL
Thanks but I don't FB.
(At least I think that's the friend request you're referring to.)
You've got my office email address anyway.
