Transmission Fluid - TCCoA Forums
post #1 of 15 (permalink) Old 03-29-2016, 02:56 PM Thread Starter
JAB
Transmission Fluid
I have a 95 with only 47k original miles. I've had it for about 30k of those miles and bought it from the original owner. As far as I know the transmission fluid has never been changed. The fluid is reddish brown and I get a shudder around 30-35mph but only when going up hills. I have read all about torque converter shudder and switching to mercon V. My question is, do you guys think it is safe to replace all the trans fluid, from pan and converter? And should I do it? Some people have told me not to drain fluid because then the trans might slip. Any info would help. Thanks.
JAB is offline
post #2 of 15 (permalink) Old 03-29-2016, 03:15 PM
Do it, drain it all!
post #3 of 15 (permalink) Old 03-29-2016, 03:30 PM Thread Starter
JAB
Something about your reply makes me unsure haha.
I guess I'm not sure if you're kidding or being serious.
JAB is offline
post #4 of 15 (permalink) Old 03-29-2016, 03:51 PM
I'm serious, sorry if it sounded like I was being a smart ass.
Drop the pan and drain the converter. Refill with the Mercon and you should be good to go.
post #5 of 15 (permalink) Old 03-29-2016, 03:55 PM Thread Starter
JAB
Thanks for the replies Joe. Do you think my shudder is due to the trans fluid, torque converter? Or would it be from a miss? It only shudders when going up a hill.
JAB is offline
post #6 of 15 (permalink) Old 03-29-2016, 07:48 PM
Draining the fluid and replacing it is fine, flushing it is the method that can cause issues in some transmissions. I definitely recommend Mercon V, Ford even put out a TSB for it, converter shudder is very common on 94-95s with original fluid.
post #7 of 15 (permalink) Old 03-29-2016, 08:51 PM
It's a breakdown of the friction modifiers that keep the clutches from slipping caused by heat over time.
You can help the trans and fluid by adding an aftermarket cooler. Peak trans temps in the 180 range will practically double your fluid life compared to peak temps in the 21x range the stock configuration gives...
post #8 of 15 (permalink) Old 03-30-2016, 05:07 PM Thread Starter
JAB
Thanks for the replies guys. So as long as I drain it and don't take it to a shop where they flush it I should be fine? I will look into getting a trans cooler. I have read about them on here and also the deeper trans pan.
JAB is offline
post #9 of 15 (permalink) Old 03-30-2016, 07:18 PM
What part of Cleveland are you in? I'm willing to lend a hand if you find yourself needing one.
post #10 of 15 (permalink) Old 03-30-2016, 07:38 PM Thread Starter
JAB
Thanks terminator. I'm in Garfield Hts, bordering Cleveland. The car gets put away every winter and I haven't taken it out yet so it may be a while before I were to do anything with it. I appreciate the offer though.
JAB is offline
post #11 of 15 (permalink) Old 03-30-2016, 07:43 PM
Tbird Bob's Avatar
I had the same symptoms in my 1995. Two of my transmission expert friends recommended this, Instant Shudder Fixx, and it absolutely worked for me.
Tbird Bob is offline
post #12 of 15 (permalink) Old 03-30-2016, 07:59 PM Thread Starter
JAB
Hey Bob. I actually tried that and it seemed to work but I didn't get to drive the car that much before I put it away for winter. I was just concerned about the color of the trans fluid, being reddish brown, and if it is no longer any good. I have read that the color can change over time without the actual fluid being bad. Thanks for the tip.
JAB is offline
post #13 of 15 (permalink) Old 03-30-2016, 09:02 PM
Tbird Bob's Avatar
I think changing the fluid certainly can't hurt, and it will give you peace of mind. When I change mine, I might consider adding this: LUBEGARD Automatic Transmission Fluid Protectant
A little insight into the history of the company: International Lubricants Inc. (ILI) - Makers of LUBEGARD
Since 1984, International Lubricants, Inc. has been a leader in researching, developing, and manufacturing patented high-performing ester-based synthetic lubricants and related products for automotive, industrial, marine and agricultural applications. It started here, during the preliminary development of the company’s proprietary LXE Technology, that International Lubricants Inc. took the opportunity to manufacture products that were friendlier to the environment, benign in their affect on users, and superior at resolving many common fluid-related difficulties. (much more to this article at the link)
Dr. Phil Landis, former head of Mobil Oil Applied Lubrication Research Group, became an automotive industry tribology pioneer through his formulation of the LXE, Liquid Wax Ester, Technology as a direct molecular replacement for sperm whale oil.
Why sperm whale oil?
Sperm whale oil and its derivatives were used as additives in virtually all automotive lubricants. The products were so effective that vehicles’ fluids were generally never changed, and systems like the transmission lasted the life of the car. Some 30 million pounds of sperm whale oil were used every year in lubricants alone. To supply the demand, hundreds of thousands of whales were harvested bringing that species to the brink of extinction.
The sperm whale was named for the valuable spermaceti oil (wax) that this whale produces in the spermaceti organ (located in its head). It has the largest brain of any animal, weighing about 20 pounds (9 kg)! The most famous sperm whale still to this day is from the fictional novel Moby Dick and was written by Herman Melville in 1851.
In 1972, the Endangered Species Act outlawed the killing of whales and the use of materials derived from those animals. For years, in engine oils, the automotive industry relied on other animal based products such as tallow or lard. For complex systems such as transmissions, these substitutes proved to be inadequate, leading to poor overall drive train performance, premature drive train failure and failure due to heat. For instance, automatic transmission failures went from less than a million units in 1972 to over eight million units a year by 1975, due to the loss of sperm whale oil additives. According to the Automatic Transmission Rebuilders Association of Ventura, Calif., today, there are over 11 million automatic transmission failures per year (and nearly nine out of ten) are caused by the degradation of automatic transmission fluid due to heat. Heat promotes the oxidation of transmission fluid, and that compromises its performance and accelerates wear on the internal components of automatic transmissions.
post #14 of 15 (permalink) Old 03-31-2016, 07:28 AM
T6Rocket's Avatar
Definitely just change the fluid, especially since it's original. It will clear the shudder right up.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #15 of 15 (permalink) Old 03-31-2016, 08:46 AM
Al
Agreed. Additives to me always seem to be a band aid fix to address symptoms of a larger problem and are IMHO only appropriate when the costs associated with the "correct" fix are prohibitive to the purpose/value/outlook of the vehicle.
Small world.
The father-in-law was raised out there. Just shoot me a PM if you ever need anything. There's at least one other member here (not active on the boards much lately) who lives out in North Olmsted too.
I'm just putting the finishing touches on the work I did on the bird while it was garaged this winter. New tires coming next month, then it's driving season 2016.
