Build Custom Rear Diff Mount? - TCCoA Forums
post #1 of 2 (permalink) Old 04-12-2016, 11:47 AM Thread Starter
MaddMartigan's Avatar
Is there any reason I couldn't just build my own custom rear differential mount?
I'm thinking like the attached pic. Does it make sense?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 2 (permalink) Old 04-12-2016, 02:06 PM
jco1385's Avatar
That is essentially what the SCP mount is. I don't see why you can't make your own? Alan was toying with different designs a little while back as well.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
