Does Anyone Run 3.73 Gears in Their Mark VIII ??? - TCCoA Forums
 3Likes
  • 1 Post By Trunk Monkey
  • 1 Post By decipha
  • 1 Post By decipha
post #1 of 13 (permalink) Old 02-17-2019, 02:08 PM Thread Starter
tailfin Joe's Avatar
I have a 1998 Mark Viii CE I would like to run 373 gears what are the pros and the cons ? Thanks Joe
tailfin Joe is offline
post #2 of 13 (permalink) Old 02-17-2019, 05:18 PM
See this old club links for answers:
https://www.tccoa.com/articles/gears/gears2.html
I run 3.73's in my car and most here do. I highly recommend them.
post #3 of 13 (permalink) Old 02-17-2019, 07:14 PM
Woodman's Avatar
Pros:
Better acceleration.
Cons:
Needs a tune for correct shift points.
Higher highway RPM, close to 2600 at 75mph, not horrible, but higher than normal.
Some loss in MPG, between 22-24 mpg at highway speeds depending on a few factors.
Woodman is offline
post #4 of 13 (permalink) Old 02-27-2019, 07:51 PM
I have them .its the best mod on my tbird.big difference and my gas mileage is better.i drive in the city mostly
biker is offline
post #5 of 13 (permalink) Old 03-16-2019, 07:27 PM
Third Ford Burden's Avatar
Question
I was thinking 3.55 for my 96 Mark VIII, but sounds like MPG on the highway would not be much better...?
Third Ford Burden is offline
post #6 of 13 (permalink) Old 03-16-2019, 08:23 PM
Nope, not that big of a difference.
I think Matt runs 3.55's he could tell ya.
Third Ford Burden likes this.
post #7 of 13 (permalink) Old 03-17-2019, 12:26 AM
decipha's Avatar
usually in city driving the mileage goes up with gears
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #8 of 13 (permalink) Old 03-17-2019, 09:27 AM
I'm hoping so on my Dakota; it's a pickup which sucks already (about 17MPG or so on the highway), and I've just about to start a 40-hour-week job in town, which will make it somewhere the wrong side of fecal ...
But the truck has 2.94 rear gears in it now. I'm planning on going to 3.54 (Dodge 8.25 rear end) hoping it'll help in town some.
On my 1991, I've got a set of 3.55 gears to drop in when I get my spare pumpkin rebuilt this summer (maybe!)
That can't hurt in town any ...
Fuelly
RalphP is offline
post #9 of 13 (permalink) Old 03-17-2019, 10:53 AM
With the PI/4R70w/3.55/26” tire combo I got 28mpg highway @65mph on one leisurely trip so they’re not bad on highway by any stretch. I usually got a combined average of 18mpg with mostly city driving.
post #10 of 13 (permalink) Old 03-18-2019, 01:24 AM
decipha's Avatar
thats pretty amazing. My ls1 camaro only gets 26.5 mpgs with the cruise set to 85mph. My 03 Marauder can't even best 23mpg with the cruise set at 85mph.
I'm afraid I will never know what any of my vehicles get at 65 I simply cannot drive that slow.
Grog6 likes this.
supercoupin'
decipha is offline
post #11 of 13 (permalink) Old 03-18-2019, 11:59 AM
Woodman's Avatar
Compare apples to apples.
What transmission in the Camaro? T-56? If so, that's got a .5:1 6th gear, so your RPM's at 85 are going to be around 1900. Your Marauder has 3.55's in it if it's stock, and the 4r70W with it's .7:1 OD is going to have the RPM's around 2500, and that's well beyond the "sweet spot" for the DOHC 4.6. Add to it they're a bigger, heavier car and they just aren't going to get great MPG.
Woodman is offline
post #12 of 13 (permalink) Old 03-18-2019, 12:10 PM
On the same trip I got a $200 out of state ticket for doing 80 in a 65 zone, so I kept it at miserly 65 dead on the way back to achieve that! The rest of the time highway economy was typically the same as your Marauder.
post #13 of 13 (permalink) Old 03-24-2019, 07:23 PM
decipha's Avatar
well thats where you made your mistake
the way I see it double jeopardy prevents you from getting a repeat ticket
supercoupin'
decipha is offline
Similar Threads
How does 3.73 gears change shifts (96)? 96PRLBRD 4R70W Transmissions 12 06-27-2011 09:46 AM
Does anyone index their plugs? 94t-birdlx General Tech 11 07-02-2005 11:50 AM
Anyone replaced their "window run?" Embalmer Exterior 2 03-08-2005 02:22 AM
does anyone run this setup mn112viii Exhaust 0 12-19-2004 12:54 AM
Does Anyone Have Pics Of Clear Corners On Their 96-97 Bird? projectmayhem021 Exterior 12 08-17-2002 09:14 AM
