b&m the original - TCCoA Forums
post #1 of 8 (permalink) Old 07-30-2003, 02:21 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
b&m the original
i have a 94 4r70w and wonder the b&m trick shift the original fluid will be compatible to use in my transmission?
the guy at the part store said that it will compatible even when mercon v is required.
then after i bought it then i saw other place on the net selling synthetic one to be use on modern electronic controlled transmission.
should i return the fluid now or it will be save to be use on my car?
Casper is offline
post #2 of 8 (permalink) Old 07-30-2003, 03:51 PM
Personally, I would return it and save my money for something more useful.
Use a good quality Mercon V fluid, you will be fine.
Want a cooler running transmission? Put in an auxillary cooler.
Want a shift kit? - do a JMod.
Want it all to last longer? Change the fluid every 20,000miles (see cooler above).
JMHO,
Greg
GregFL is offline
post #3 of 8 (permalink) Old 07-30-2003, 04:11 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
i have a b&m deep tranny pan with extra 3 quart capacity and also their 28k cooler waiting to be put it on but my engine's problem are holging back my time now.
thanks for the reply and i will do exactly what you told me.
thanks
Casper is offline
post #4 of 8 (permalink) Old 07-30-2003, 06:35 PM
Before I joined the boards, I bought the Trick Shift, and put it in. Stage 1 didn't do anything, Stage 2 shifted harder, but made the soleniods in the transmission click constantly. Then I read about it, and never used it again. It raises the line pressure in your tranny too high, which is bad. I still have it in the garage somewhere. Save the money for the JMod.
Rich95XR7 is offline
post #5 of 8 (permalink) Old 07-30-2003, 09:23 PM
Cougar Pilot
BlackCat94's Avatar
He mean the Trick Shift ATF, not that electronic shift improver garbage thing
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #6 of 8 (permalink) Old 08-02-2003, 10:29 AM
The Great Obucina's Avatar
i have a friend whose dad used it in his 700R4 Camaro...he said his dad did some research and found out it was just some kind of modified Mercon 3.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 8 (permalink) Old 08-02-2003, 03:20 PM
Oops, sorry, I guess I need to slow down and read more carefully. Oh, and just use Mercon V.
post #8 of 8 (permalink) Old 08-03-2003, 01:48 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
joseph
oh my god, i can't believe i've paid the price of more than mervon v to get mercon 3.
15 quarts cost me about $60 bucks. wonder where i throw my resits at????
is the valvoline mercon v good or the ammco one better?
Casper is offline
