355's or 373's................ - TCCoA Forums
post #1 of 8 (permalink) Old 08-04-2003, 10:57 PM Thread Starter
Which gears should I go with..........recommendations please.
z
90s/c,MPII blower & plenum,CMRE Stg 1 heads/cam,3/4 raised top,85mm MP TB,42# injectors,85mm ProM MAFS,MP CAI,Kooks mids w/3" mid pipe & Magnaflows, AOD w/trans-go,trans-cooler,373's, SCT Chip tuned by Ed Clark,10% SC pulley,5% JS pulley,ASP u/d pullies,MP FMIC,AADCO 1 3/8" swaybars,clear corners,Eibach prokit.....BLOWN UP......ANYONE NEED PARTS........now have 2 MRK VIII's
z90sc is offline
post #2 of 8 (permalink) Old 08-04-2003, 11:08 PM
You didn't post what you have, or what you hope from the car.
Generally, if you want a lower gear, you should go up at least two gears to make it worth the money (ie if you have 3.27, 3.55 would be a waste). Same thing for going to a higher (numerically lower) gear. Also depends on what you want to do with the car. If you are heading to the dragstrip, then 3.73 or even 4.11 may be what you want. If you are heading to the Salt Flats, then maybe 2.73 or 3.08 are what you want.
Hope this helps.
Dan
2008 Nissan 350Z Grand Touring
2010 Ford F150 Lariat
a bunch of motorcycles
(haven't come across my dream 97 Tbird yet)
DanQ is offline
post #3 of 8 (permalink) Old 08-04-2003, 11:25 PM Thread Starter
Thanks for the reply......I've got stock 327 rearend...looking for more bottom end "grunt" for the 1/4 mile but still "streetable"..
z
z90sc is offline
post #4 of 8 (permalink) Old 08-04-2003, 11:43 PM
Well... a 3.73 would be around a 12% lower gear, and a 4.11 would be about 20%. The 3.55 would only be about 7% and change. I'd go for anything over 10% for a noticable change. 20% if you really want to see a difference. a 4.11 should only change your rpm by about 460 rpm at what is now 2200 rpm cruise. It will come out of the hole like a bat out of hell, and you'll have to catch second in much quicker time, but it will definitely scoot.
Hope this helps some.
Dan
DanQ is offline
post #5 of 8 (permalink) Old 08-05-2003, 05:08 PM
On Probation
blown96bird's Avatar
I would chose 3.55s they are a good all around gear ration not a highway gear like the 3.27 are and not a city gear like the 3.55 are but a good compermise. 3.73 are not much use if you are going to cruise at 85 mph.
blown96bird is offline
post #6 of 8 (permalink) Old 08-05-2003, 05:53 PM
Send a message via AIM to Jason
3.55's would be a waste of time you could just send me the money instead cause your not gonna tell a difference...... 3.73's are the best compromise for your wants ( low end grunt )
I went to 3.73' s (from a 3.27) and felt a difference but it wasn't OH my goodness wow kinda feeling... But it was definately much more low end peppy.... I would have went with a 4.10 gear but I knew that I was going to swap a 5-speed in my car in the future and 4.10 plus the low first gear of a t-45 tranny would have just been too low for me
Lots of Stuff, but the important one is a "5-speed" 4.6L V8 (for sale)
2006 Toyota Tundra 4wd (new vehicle), to pull my boat one day when I get a boat
Jason is offline
post #7 of 8 (permalink) Old 08-05-2003, 05:55 PM
I'm sure the engine characteristics of the SC are different from my PI motor. That being said; my car loves 80mph with the 3.73's.
Eric Z. is offline
post #8 of 8 (permalink) Old 08-05-2003, 06:00 PM
Drive XR7's Avatar
Send a message via AIM to Drive XR7
SuperCoupe?
For a 5-speed, go 3.55s.
For an AOD, go 3.73s.
Jason
2003 SVT Mustang Cobra #5364
2001 Pontiac Grand Prix GTP
1991 Mercury Cougar XR7 5.0L - SOLD!
Drive XR7 is offline
