'01 stang 4r70w - TCCoA Forums
post #1 of 4 (permalink) Old 08-07-2003, 09:25 AM Thread Starter
JoeyICU's Avatar
'01 stang 4r70w
what would it take to put a mustang automatic in my bird?...do these trannies bolt right up....will i need any more suplies other then the tranny and my old tranny.....i plan to get some quotes from shops on doing this swap
JoeyICU is offline
post #2 of 4 (permalink) Old 08-07-2003, 11:47 AM
I believe all you need to do is change the solenoids in the tranny with your current ones. There may be more involved, but I think that's the big part.
Rich95XR7 is offline
post #3 of 4 (permalink) Old 08-07-2003, 11:52 AM
JustinH's Avatar
the biggest part is that your speedometer will not be accurate if you are running a rear end ratio higher than 3.27.
This is due to the mustang output shaft.
So, if you want to run 3.73's with a mustang 4r70w then you need to take apart the transmission and install a thunderbird/mark output shaft.
The output shaft is the first thing that goes in the case during a rebuild, so you will have to start at point one.
JH
JustinH is offline
post #4 of 4 (permalink) Old 08-08-2003, 01:00 AM Thread Starter
JoeyICU's Avatar
ill worry about that when i get a new rear end as with my budget and plans i dont seee that hapening very soon
JoeyICU is offline
