Diff oil capacity? - TCCoA Forums
post #1 of 4 (permalink) Old 08-08-2003, 06:44 AM Thread Starter
gavinl's Avatar
Diff oil capacity?
I searched but could not find the answer
What's the oil capacity of a non-tracklok (if it makes a difference) rear diff?
gavinl is offline
post #2 of 4 (permalink) Old 08-08-2003, 09:19 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Capacity, for the 8.8" ring gear version, is 1.5 litres (or 3.25 pints). For the 7.5" ring gear, capacity is 1.4 litres (or 3 pints).
From the 1994 Ford Service Manual:
All conventional axles use Motorcraft Premium XY-90-QL (ESP-M2C154-A) lubricant or equivalent, plus 4 ounces of friction modifier additive EST-M2C118-A (C8AZ-19B546-A) or equivalent for Traction-Lok axles. Always fill rear axle to bottom of filler hole.
IronChopz is offline
post #3 of 4 (permalink) Old 08-08-2003, 10:55 AM Thread Starter
gavinl's Avatar
Thanks IronC! Now I can go get some gear lube
gavinl is offline
post #4 of 4 (permalink) Old 08-08-2003, 12:57 PM
4 Cam Bird's Avatar
Keep in mind he said 3.25 pints and not quarts. You'll only need to buy 2 quarts when you go get it and you won't use it all then.
2011 CTS-V Wagon
4 Cam Bird is offline
