1-2 Accum Piston Jmod Help - TCCoA Forums
post #1 of 15 (permalink) Old 08-09-2003, 12:20 PM Thread Starter
Cordeez's Avatar
Exclamation 1-2 Accum Piston Jmod Help
I finally got the 1-2 accum piston out after finally finding a decent set of pliers, but now of course, another problem. I can't seem to get the 1-2 piston back in to the VB. I've searced and noticed that a lot of people used Jacks to put it back in. How exactly do I use the jack? Do I need any other pieces for height? What do I use to press against the bottom of the piston setup? Does the piston go in gradually or all at one? Thanks.
-Cordeez
15.106 @ 92mph
CAI
Apten Chip + 22C + 180 Tstat
Steeda UD Pulleys
PI Intake
Coming Soon: PI Cams
Cordeez is offline
post #2 of 15 (permalink) Old 08-09-2003, 12:44 PM
Are you putting in a bottom spring? When I did mine, I left out the bottom spring, and pushed the accum up a bit. A few times it wouldn't give, then all of a sudden it gave in and went about another .5 -1" higher. Try rotating it and it should give in.
RyanG is offline
post #3 of 15 (permalink) Old 08-09-2003, 12:53 PM Thread Starter
Cordeez's Avatar
What did you use to go from the jack to the bottom of the piston setup?
15.106 @ 92mph
CAI
Steeda UD Pulleys
PI Intake
Cordeez is offline
post #4 of 15 (permalink) Old 08-09-2003, 05:56 PM
Remember, there are seals around the accumulator.
You don't want to shear them with the edges of the bore.
Lube it up really good with ATF, lube the bore as well. Press on it by hand until it pops into place, it may help to wiggle it a little.
Then replace the lower spring (if you drive in the rain ) and the cover. Have a friend hold it in place with a wooden hammer handle or large dowel, and replace the snap-ring. You can use a bottle jack, etc. along with the wood if you don't have help, but be careful not to press on it too hard - just enough to hold the cover in place.
FWIW
GregFL is offline
post #5 of 15 (permalink) Old 08-09-2003, 07:16 PM
MadRussian's Avatar
Send a message via AIM to MadRussian Send a message via MSN to MadRussian Send a message via Yahoo to MadRussian
Hey,
I know exactly what you are talking about when you say it does not go in.
I dont know if you are using a spring or not, but if you are and the spring is what is preventing you from pushing in the accunulator then you can use a jack with a lare socket on top of it to help you push it into the bore. BE CAREFUL NOT TO FORCE IT INTO THE BORE.
Most likely though you are not using a 1-2 spring, you just have to lube the pison and bore, and keep trying to put it in, you have to make sure it is perfectly aligned and straight when you put it in, just keep trying...it will get in there.
-Andrey
96 LX 4.6L
13.215 @ 103.09
MadRussian is offline
post #6 of 15 (permalink) Old 08-09-2003, 10:17 PM
I didn't have to use a jack on the 1-2 accum when I recently installed my shift kit. I did on the O/D servo, though, which I had mistakenly dropped! The accumulator should go back in with a little wiggling around & some trans fluid on the seals. I hope you have the new type accumulator. The old aluminum type that I had leaks by badly. Picked up the new steel one at a dealer. Like the other guys said, rotate & wiggle it & it should go on up inside.
mcate is offline
post #7 of 15 (permalink) Old 08-17-2003, 12:39 PM
Hi All,
Well I got the spring off put the 1-2 piston cover well not drop down,
Is thier a trick to this?
I can rock it back and forth but it well not come down.
quadcells is offline
post #8 of 15 (permalink) Old 08-17-2003, 02:31 PM
I assume you mean you got the snap ring out..
If so, the 1-2 accumulator piston cover has a rubber seal around it - this is good.
The bad part is that it may be difficult to remove because of it.
Try gently prying the inside of the cover with a screwdriver, or of you have a LARGE set of external snap ring pliers, you can just clamp the inside lips of the cover with the snap ring plier jaws and pull it out. It shouldn't be THAT tight, just a little snug because of the rubber surround. Don't damage the rubber part where it seals against the bore, you want that to be in good condition - and don't bend the cover.
Usually the 2 springs will push it out, but if you have a 3.8 engine, there is no upper spring, and it will not pop out on it's own. If the lower spring is broken, there may be shards of it jamming the cover and they may have deformed the cover - I've seen it happen. You should replace the cover if it is damaged too much - it's cheap insurance.
GregFL is offline
post #9 of 15 (permalink) Old 08-18-2003, 07:33 AM
Well it must be the o-ring; I can't seem to get it out.
I would hate to put this back together without fixing that broken spring. But I need my car. Is their some kind of tool that has a strong suction cup on it?
post #10 of 15 (permalink) Old 08-18-2003, 11:32 AM
Silver95Bird's Avatar
when my accumulators stick, i get a pair of needlenose pliers - but instead of closing them up, open them so that the ends are against the sides of the accumulator. then pull down, and the whole red mess will come right down. lol. Don't wear your sunday best for this job.
Silver95Bird is offline
post #11 of 15 (permalink) Old 08-18-2003, 12:26 PM
Smile
Hi Silver95Bird,
It was the cover to the 1-2 accumulator that I couldn't get out. What I did was start the engine for 2 seconds and that pushed the cover down so I could grab it.
This is what the spring looked like when I removed it. It was in side ways too.
Here is a pic of the new spring and 1-2 accumulator:
and a pic of the inside of the 1-2 cover:
All assembled and it shifts great..no more bang when it shifts into second and so far no shudder.
Thanks to all of you
post #12 of 15 (permalink) Old 08-18-2003, 12:37 PM
holy sheet, that was pretty bad. Glad you got it working again
RyanG is offline
post #13 of 15 (permalink) Old 08-18-2003, 01:45 PM
See, persistance pays!
Curious, did you replace that chewed up 1-2 cover?
Glad you got it going.
GregFL is offline
post #14 of 15 (permalink) Old 08-18-2003, 03:16 PM
Yes I did replace the 1-2 cover.
I just changed the fluid and filter on my wife's 97 Expy.
80,000miles and you know I found that plug in the pan.
I guess all they do is change fluid and not filter.
post #15 of 15 (permalink) Old 08-18-2003, 11:51 PM
holy cow, lol
glad to see you've fixed it
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
