Urgen! Need Help Badly! - TCCoA Forums
post #1 of 5 (permalink) Old 08-09-2003, 06:15 PM Thread Starter
Cordeez's Avatar
Exclamation Urgen! Need Help Badly!
oK, i just finished doing the j-mod and it wont let me shift into drive, 1, or 2, and I can't catch any gears. i've watched my rooster tail and it won't let me past drive.
We need help AS SOON AS POSSIBLE! If you are in the Maryland area you can reach me at (240)305-9987. Thanks..
Cordeez
15.106 @ 92mph
CAI
Apten Chip + 22C + 180 Tstat
Steeda UD Pulleys
PI Intake
Coming Soon: PI Cams
Cordeez is offline
post #2 of 5 (permalink) Old 08-09-2003, 06:31 PM
Did you get the shifter lever pin into the manual valve correctly?
This is an all too common mistake.
Look here to see the correct way...
http://videodoc.home.mindspring.com/...ShiftLever.jpg
GregFL is offline
post #3 of 5 (permalink) Old 08-09-2003, 08:16 PM
the manual valve isnt lined up with detent wheel. The detent wheel goes into the skinny part of the manual valve. I had the same prob. Also check your rooster spring. I have a thread here somewhere with some EXCELLENT photos from another member.
RobinCali is offline
post #4 of 5 (permalink) Old 08-09-2003, 09:05 PM
Would that have been the one I posted for you, and the OP above?
GregFL is offline
post #5 of 5 (permalink) Old 08-10-2003, 07:06 PM
