Grease Explosion? - TCCoA Forums
post #1 of 6 (permalink) Old 08-10-2003, 08:46 AM Thread Starter
Grease Explosion?
On my way home this morning, I was sitting at a light, light turns green and as I start to accelerate, I hear one of those trademark not so good sounds coming from the rear of my car. Every gear is neutral for the car now so pushing it home at 2am wasnt that hard.
Just a few minutes ago I got under the car to find out what exactly happened and there is a ton of grease splattered all over the exhaust and the sheild for the gas tank on the drivers side. My best guess is either the halfshaft snapped or I lost some kind of seal that finally let go.
Just curious if anyone else has had something like this happen and if so, what needed to be fixed. tia
ChitownLX is offline
post #2 of 6 (permalink) Old 08-10-2003, 10:45 AM
Sounds like the CV joint nearest to the greasy spots let go. Time for a new half shaft bud.
Warped is offline
post #3 of 6 (permalink) Old 08-10-2003, 02:46 PM
Here is what you'll likely find when you get under there:
-Rod
post #4 of 6 (permalink) Old 08-10-2003, 02:47 PM
And if you're really unlucky (hey, like me for instance), you'll find this too.
-Rod
post #5 of 6 (permalink) Old 08-10-2003, 07:11 PM Thread Starter
After a closer look, it doesn't look like the differential is cracked like yours. Luckly the extended warranty (best idea ever) covers the rear axle. So i'll find out the extent of the destruction tomorrow. Maybe I can get a better pair instead of stock parts
post #6 of 6 (permalink) Old 08-10-2003, 07:23 PM
Well, the best route you can take (besides Raxles) is to replace the stock halfshafts with those from a 5-speed SC.
-Rod
