Will 8.8 Rear Out Of 89' Cougar Work In 89' Bird With 7.5 Rear????? - TCCoA Forums
post #1 of 10 (permalink) Old 08-20-2003, 12:07 AM Thread Starter
I BLEW OUT MY REAR DOING DOUGHNUTS THE OTHER DAY SO I GOT ONE OUT OF AN 89 COUGAR FROM THE JUNKYARD, THE ONLY DIFFERENCES I SEE IS THAT THE COUGAR HAD AN 8.8 REAR END WITH DISC BRAKES, AND MY BIRD HAD A 7.5 REAR WITH DRUM BRAKES. WILL THESE DIFFERENTIALS MATCH UP WHEN I GO TO SWAP THEM??
BirdMan89 is offline
post #2 of 10 (permalink) Old 08-20-2003, 10:46 AM
yes, its a DIRECT bolt in.
rancherlee is offline
post #3 of 10 (permalink) Old 08-20-2003, 03:34 PM Thread Starter
SO, HAVE YOU DONE THIS BEFORE, OR HAVE YOU JUST HEARD THAT THEY BOLT RIGHT UP?
post #4 of 10 (permalink) Old 08-20-2003, 06:25 PM
Many of us here have replaced/swapped centersections (pumpkins) quite a few times. As rancher said, it's a bolt in.
-Rod
post #5 of 10 (permalink) Old 08-28-2003, 05:17 PM Thread Starter
GOOD NEWS, THE 8.8 WENT IN WITH NO TROUBLE!!! WHAT ARE THE DIFFERENCES BETWEEN THE 7.5 AND 8.8 REAR END? WHAT DO THE NUMBERS ACTUALLY MEAN?
post #6 of 10 (permalink) Old 08-28-2003, 05:25 PM
Just one thing dude, turn the caps lock off, please.
Rich95XR7 is offline
post #7 of 10 (permalink) Old 08-28-2003, 09:24 PM
7.5 = 7.5" ring gear
8.8 = 8.8" ring gear
-Rod
post #8 of 10 (permalink) Old 09-03-2003, 08:43 PM
Also, the 8.8" will handle quite a bit more torque than the 7.5" will.
But you have already tested the TQ limits of the 7.5"!!!!!!
68COUGAR
68COUGAR is offline
post #9 of 10 (permalink) Old 09-03-2003, 09:07 PM
JustinH's Avatar
Were you referring to Rancher?
I found that post quasi-humorous.
JH
JustinH is offline
post #10 of 10 (permalink) Old 09-03-2003, 09:46 PM
Both 7.5" and 8.8" ring gear varieties are equipped with 28-spline axles, thus a direct fit. 7.5" is worthless for performance use. A stock 5.0 175 horse engine will generally destroy this assembly with little effort. 8.8" is an awesome piece, it will last you through a lot of abuse. The axles can be easily recognized by the inspection covers. The 7.5 has only two straight sides, top and bottom, the 8.8 is basically a square with rounded corners. Unless you have a posi 3.55 gears are the max you should have on open rear.
mad281 is offline
