Upgrading to 03 Cobra Rad. What size trans cooler do I use? - TCCoA Forums
post #1 of 14 (permalink) Old 08-20-2003, 12:12 AM Thread Starter
As you may or may not know they do not come with trans coolers.I've done a search and found nothing. Will my 24,000 gvwr trans cooler be enough?
2000 GT engine
Nakamichi CD 500, Nakamichi MB 70 in dash cd changer, three Nakamichi amps (1000 watts), 10 inch sub, MB Quart speakers (4 5x7 and 2 6x9)
2003 Mustang Mach 1
"The fast ones always ride for free"
Andrew Wood (R.I.P.) Mother Love Bone
BlackBird is offline
post #2 of 14 (permalink) Old 08-20-2003, 08:08 AM
Overkill Fetish Freak
Yes, your 24,000 gvwr will be fine. Even in the super humid and hot GA heat with the AC on MAX I see TOT's of 140-160 now that the rad cooler is out of the mix but I do have a B&M deep pan also that aids in the cooling as well. My ECT's range from 180-195 and again this is in 90+ degree weather with a lunatic at the wheel so I'd say the Cobra rad is doing a very nice job.
-Scott
"Cry for the saviors and the prophet's son "
-MLB
Dr. FrankenCougie is offline
post #3 of 14 (permalink) Old 08-20-2003, 10:00 PM
Fry Rice Specialist
Casper's Avatar
i also have the b&m deep pan waiting to put on. just wonder how about the ground clearence? will i still be able to lowered my car in the future without scraping?
i ask this question before but found no answer.
thanks
CarDomain Page
Casper is offline
post #4 of 14 (permalink) Old 08-21-2003, 12:18 AM Thread Starter
Thanks Scott! I'm bypassing the radiator tomorow and the Cobra rad should be in Monday, just in time for my Labor Day trip to Vegas!!
Eric
2000 GT engine
2003 Mustang Mach 1
post #5 of 14 (permalink) Old 08-21-2003, 07:25 AM
Chuacw, I have not had any issue with the pan scraping and my ride is lowered.
-Scott
post #6 of 14 (permalink) Old 08-21-2003, 12:42 PM
Sweet T
SanDiegoLXBird's Avatar
Frankencougie,
How well does the 96+ filter work with that B&M deep pan.. or does it use a special filter? (IE does it have the problems the flat pans from 95 and previous did)
1994 SC 5-Speed
SanDiegoLXBird is offline
post #7 of 14 (permalink) Old 08-21-2003, 12:51 PM
The 96+ filter works fine.
post #8 of 14 (permalink) Old 10-29-2003, 06:09 PM
Fry Rice Specialist
Casper's Avatar
thanks Dr. FrankenCougie.
the deep pan already on there and even with the exhaust piping.
just lowered the car with eibach prokit not too long ago and i have the same pan with yours.
CarDomain Page
Casper is offline
post #9 of 14 (permalink) Old 10-29-2003, 08:18 PM
I've been running the Cobra Rad for over a month here in hot/humid S. Florida and my engine is running noticably cooler on the street , the highway an at the track. It's a good mod. Thanks again to Big Scott for posting it....
I've got a 28,000 B&M cooler (probably overkill) with '96 pan, but 24,000'll be fine...
96 GoldBird
N/A:
96 GoldBird is offline
post #10 of 14 (permalink) Old 10-29-2003, 08:28 PM
Fry Rice Specialist
Casper's Avatar
i also have the overkill 28k cooler and even after long drive the cooler is just warm instead of hot. wonder what will happen if the oil is too cold.....
CarDomain Page
Casper is offline
post #11 of 14 (permalink) Old 10-29-2003, 09:01 PM
Ask the guys in Minnesota and N. Dakota..... I don't think I'll ever have to worry about that down here....
96 GoldBird
N/A:
post #12 of 14 (permalink) Old 10-29-2003, 10:41 PM
Cougar Pilot
BlackCat94's Avatar
Oh it will warm up plenty fast. But then again on the back of the Mercon V bottle it plainly says 'Do not freeze'. I don't know how cold it has to get to freeze but when your car is running down the road it will definately stay above freezing.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #13 of 14 (permalink) Old 10-30-2003, 10:25 AM
Fry Rice Specialist
Casper's Avatar
what mercon v are you using?
mine is castrol mercon v and didn't remember reading something about do not freeze?
here in michigan are about to snow soon and the temperature will sometimes drop to -10 or -20. if that so should i block partial of the cooler fin off by board?
CarDomain Page
Casper is offline
post #14 of 14 (permalink) Old 10-30-2003, 02:55 PM
I havn't noticed any issues with the temps in the high 20's low 30's here, but thats about as cold as I'll drive it in before it goes to bed for the winter.
chadg is offline
