Helllllpppp, rear end confusion - TCCoA Forums
post #1 of 11 (permalink) Old 08-24-2003, 07:46 PM Thread Starter
Ashish's Avatar
Send a message via AIM to Ashish
Question Helllllpppp, rear end confusion
The Tech articles says i have a open rear end code is (W5), but I bust both wheels when i power brake or burn out. I also have traction control if it makes a difference. So my question is do I have trac-lok or not?
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #2 of 11 (permalink) Old 08-24-2003, 08:24 PM
MadRussian's Avatar
Send a message via AIM to MadRussian Send a message via MSN to MadRussian Send a message via Yahoo to MadRussian
If you have traction assist, then you don't have trac-loc
-Andrey
96 LX 4.6L
13.215 @ 103.09
MadRussian is offline
post #3 of 11 (permalink) Old 08-24-2003, 09:28 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
If you are getting both wheels to go while burning out you must be on nice even ground and just getting lucky. As said above if you have TA you don't have trac-lok.
Wet one tire and leave one dry and you will just spin the one wheel, which means open rear end.
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #4 of 11 (permalink) Old 08-24-2003, 10:46 PM Thread Starter
Ashish's Avatar
thanks guys, ill reread my door code maybe I am wrong, cause I can lite both of them up anywhere, even while turning, on dirt. Gotta go do some burnouts
1998 Z28 M6 5.7 LS1
Ashish is offline
post #5 of 11 (permalink) Old 08-24-2003, 11:41 PM
5.0 Chero's Avatar
jack the rear end up and look at the tag it the only wat to tell!
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #6 of 11 (permalink) Old 08-25-2003, 12:11 AM Thread Starter
Ashish's Avatar
since it is a open rear end that does two wheel peel, should I still get the Trac-lok in the future?
1998 Z28 M6 5.7 LS1
Ashish is offline
post #7 of 11 (permalink) Old 08-25-2003, 06:09 AM
Maybe the original rearend was replaced with a traction lok rear.
post #8 of 11 (permalink) Old 08-25-2003, 12:18 PM Thread Starter
Ashish's Avatar
i doubt that the whole car looks bonestock, it has 112,000 with still the 1997 spark plug wires
1998 Z28 M6 5.7 LS1
Ashish is offline
post #9 of 11 (permalink) Old 08-25-2003, 12:37 PM
As mentioned by 5.0 Chero, you can take a look at the tag on the diff cover to determine if you have a Trac-Loc or not. If that is the factory centersection (pumpkin), then it defintely is an open carrier.
-Rod
post #10 of 11 (permalink) Old 08-25-2003, 02:08 PM
i have an open rear end, and i can still spin both wheels
traction lock, doesnt meen you can't spin both, it just means that one wheel will only slip so much before its locked into the other one. Even without traction lock you'll still be able to spin both wheels
tony
ton6y is offline
post #11 of 11 (permalink) Old 08-25-2003, 03:44 PM
5.0 Chero's Avatar
tony
No actually they are "LOCKED" together with clutches and a spring! The clutches let one wheel turn at a different speed when going around corners. The clutches will get worn and than you can get one wheel peal! if you get one wheel to slip with track lock it need a rebuild!! A true locker locks both axles with gears or teeth that lock together and usually pop around corners or chirp the tires!
THE PYL !
86 F250 Diesel 4x4
GONE 89 Aerostar
1996 Exploder
