Excessive hard shifting from 1st to 2nd gear... - TCCoA Forums
post #1 of 2 (permalink) Old 08-27-2003, 05:44 PM Thread Starter
I have a '96 Thunderbird (LX 3.8L V-6) that shifting is hard between gears 1st and 2nd, but is smooth as can be though following gears... I just aquired the car and did a full ATF change including 2 quarts of lucas trans oil, to see if that helps fix the problem it's helped smooth the ride but hasn't done anything to the 1st & 2nd problem. Took it to a Trans shop and they said it is probally the PCM and would probally need to be replaced. I want to try to actually narrow the problem...Thanks for any insight that you may have.
wall77 is offline
post #2 of 2 (permalink) Old 08-27-2003, 06:17 PM
Take a look at this thread
-Rod
