89 Cougar 3.8 auto won't shift out of 1st - TCCoA Forums
post #1 of 5 (permalink) Old 09-04-2003, 10:17 AM Thread Starter
So this past weekend, I went to drive the 89 Cougar that my uncle gave me home. I had a little trouble getting it going because of a bad coil wire, but I took care of that. I started to drive up the road, and it wouldn't shift out of first. I held it at about 50 km/h for a bit, hoping maybe it would shift eventually, but no luck. I don't know why it's doing this now, just two weeks ago when I had it out, it shifted perfectly. Maybe a fluid and filter change will help?
Villageidiot is offline
post #2 of 5 (permalink) Old 09-04-2003, 12:54 PM Thread Starter
Ok, from digging through old posts on this forum, it appears I'm going to have to adjust the Tv cable, and replace the 1-2 accumulator. Is there a guide to replacing the 1-2 accumulator?
post #3 of 5 (permalink) Old 09-05-2003, 03:50 AM
Doug Franklin's Avatar
Did the TV cable come off on either end?
95-5spd SC and a few others, TCCoA, SCCoA, Fordbastards, Motorsport Ranch (MSR)
Doug Franklin is offline
post #4 of 5 (permalink) Old 09-05-2003, 08:16 PM
Lazania's Avatar
you shouldnt have to replace the 1-2 accumulator unless you have a 94 or newer , but the TV cable is probley your problem. Good luck let me know how you make out
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #5 of 5 (permalink) Old 09-05-2003, 09:53 PM
I had to have a rebuild for driving with a TV broke off.
