Gear installation? - TCCoA Forums
post #1 of 13 (permalink) Old 09-20-2003, 02:01 AM Thread Starter
The Band, not the Disease!
AnthraxBird's Avatar
Gear installation?
OK, nows the time for some new gears. 3.73's. I got the 97 4.6, with the 3.23 trak lok rear end. What special tools do i need? Any advice? I've got great mechanical ability and more tools than I will ever need, so none of that is an issue =) Please help?
AnthraxBird is offline
post #2 of 13 (permalink) Old 09-20-2003, 03:34 PM Thread Starter
Anyone? Please? TTT
post #3 of 13 (permalink) Old 09-20-2003, 05:26 PM
miller1995's Avatar
Check the tech articles, I'm pretty sure there is one for gears.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #4 of 13 (permalink) Old 09-20-2003, 06:11 PM Thread Starter
There is no article on how to change gear ratios =(
post #5 of 13 (permalink) Old 09-20-2003, 06:13 PM
Pedal Faster
Josh_Keady's Avatar
http://www.kellnet.com/chambers/gearset_install.htm
That should do 'ya. Live axle, but close enough.
Josh Keady
Josh_Keady is offline
post #6 of 13 (permalink) Old 09-23-2003, 04:01 AM
Aaron_T's Avatar
You probably will want to take the whole differential out to do the gears.
It will make it a whole lot easier. The crush collar takes A LOT of force to crush down, and there really isn't enough room under the car (it can be done but...)
You also should replace your axel seals, pinion seal, pinion nut, and you have to replace the crush collar. You don't need a cover gasket, just some high-temp rtv. You may also need to replace your bearings, mine were still good at around 60,000 miles.
You can either get a install kit from Summit (comes with shims), or just buy the indivual parts from a gear shop. I think my seals, crush collar, and nut came to $30.
The person who helped me had shims, but we didn't need to change the factory ones, they worked perfect for mine.
As for tools, you need an inch/pound torque wrench to check the back lash, and a dial indicator. There is also a "paint/grease" you need to make sure the gears are setup right as well, but I forgot what it's called. This will tell you what you need to do shim wise.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #7 of 13 (permalink) Old 09-23-2003, 10:44 AM
how much does a shop usually charge to install gears?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #8 of 13 (permalink) Old 09-23-2003, 01:25 PM
Around $200
Rich95XR7 is offline
post #9 of 13 (permalink) Old 09-23-2003, 01:57 PM
Aaron_T's Avatar
If the diff. is in the car, they charge $500-$700 up here w/o the gears. I am sure it would be closer to what Rich said if it was off of the car.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #10 of 13 (permalink) Old 09-23-2003, 05:02 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
A guy I know said that the ford dealer installed his gears (out of car) for $100. That's the route I'm goign when I install my 3.73s because I SCREWED up my 3.55 install
-Rob
-Rob
Rob is offline
post #11 of 13 (permalink) Old 10-02-2003, 12:16 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
aaron,
i am undecided between 3.73's and 4.10's. How are the 4.10's? what rpms are you at while driving around town? what about on the highway at about 70-75 mph? did you upgrade your driveshaft? thanks.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #12 of 13 (permalink) Old 10-02-2003, 04:43 PM
DirtyBird46's Avatar
Send a message via AIM to DirtyBird46
3.90's!!!!! That is what I am getting when I get the money. I couldn't decide between 3.73 and 4.10 so I split the difference.
DirtyBird46 is offline
post #13 of 13 (permalink) Old 10-02-2003, 09:13 PM
Aaron_T's Avatar
Originally posted by fdawg97lx
aaron,
Frank
I just got done writting down different mph/rpm numbers -
30mph - around 1700rpm (3rd)/2100 in (2nd gear)
40mph - 2000rpm
50mph - 2500rpm
60mph - 3100rpm in 3rd, 2200rpm in o/d
80mph - 4300rpm in 3rd, 3000rpm in o/d
I drive around town w/ o/d off most of the time (the tranny shop told me to stay out of o/d as much as possible). I have been a little over 110mph with these gears. Not that I couldn't go any faster, but I didn't have much room to go any faster (probably could have got 130mph out of her).
Before the gears I went close to 150mph until I decided to shut down.
This is on the STOCK driveshaft. At the end of the 1/4 mile now I can feel the d/s start to vibrate (not too bad), but I am definitely getting a good d/s for the nitrous (don't have the nitrous yet). I will for sure have the kit before next summer, and I do not wanna run the 1/4 mile with that d/s and these gears.
I noticed on your 'reader's ride' page you were planing on doing a lot to your car, so if I were you I would go with the 4:10's. With a power adder I bet they will help out a lot (and I noticed you had a Zex kit in future mods). My gas mileage is still good unless I romp on it (which I do often), and I also drive most of the time w/ overdrive off, so that kills my gas mileage right there.
So if you drag racing/light to light race often enough, then go for the 4:10's. The gas mileage difference won't be that huge (than form the 3:73's), and if you like to top end race, then with the Zex you will have no problems. I love my 4:10's now, but with the added power from nitrous, they should really kick a$$.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
