5R55E Swap - TCCoA Forums
post #1 of 6 (permalink) Old 09-21-2003, 01:39 PM Thread Starter
Boom.
Palmguy's Avatar
5R55E Swap
Maybe I'm just dreaming here, but that's why I'm asking. I've been driving my dad's '99 Explorer for the last few days and I really love it, specifically the tranny. The five-speed auto does a great job of keeping the SOHC 4.0L V6 in it's powerband, and it is sweet to get on it and a shift only drop the RPMs drop a couple of hundred instead of a couple of thousand on our wide-ratio transmissions.
Here's the question: There is a 5R55E that will bolt to a 4.6 block ('02-04 4.6L Explorers), so is it possible without too much extra effort to put this bad boy in? I assume that I will need a new DS and computer work, but how about the crossmember etc.?
No one has ever seriously brought this up here, and I may just volunteer myself to be a guinea pig if I can get some more info on it.
5R55E Gear Ratios:
1st: 3.22
2nd: 2.32
3rd: 1.55
4th: 1.00
5th: 0.71
R: 3.07
Sounds like fun! Should feel quicker off the line with the 3.22 1st gear ratio versus our 2.84.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #2 of 6 (permalink) Old 09-21-2003, 03:37 PM
Pedal Faster
Josh_Keady's Avatar
I saw one of those in a tranny shop the other day, and I may be wrong, but it looked WAY bigger than either the 4R70W or the AOD, even the C6 (which people have kind of determined won't fit in the MN-12 without modification to the floor pan.)
I don't know though, it might work... someone needs to get the dimensions on both first.
Josh Keady
Josh_Keady is offline
post #3 of 6 (permalink) Old 09-21-2003, 04:39 PM
Refrigerator Raider Hater
GreenBird's Avatar
You'd probably need a shortened driveshaft too.
Not sure, but if I am deciphering the trans model # correctly, it wouldn't stand up to as much torque. Probably plenty for a semi-stock bird though.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 6 (permalink) Old 09-21-2003, 05:05 PM
According to what I've found, the 5R55E's gear ratios are:
1 - 2.47
2 - 1.87
3 - 1.47
4 - 1.00
5 - 0.75
The 5R55W's gear ratios are:
1 - 3.22
2 - 2.41
3 - 1.55
4 - 1.00
5 - 0.75
Only problem with the 5R55's is they seem to be sealed "maintenance-free" transmissions...
Best times:
Cougar281 is offline
post #5 of 6 (permalink) Old 09-21-2003, 07:24 PM Thread Starter
Boom.
Palmguy's Avatar
That's what I was thinking too...although it would be enough for me I think. I'll have an Explorer 4.6 parked in front of whatever trans. I get, with no plans for power adder or serious rebuild anytime in the next few years.
I'll probably end up with just a newer 4R70W, but it sure is nice to think about.
I just found some more info on the gear ratios, you are right about them. I guess the previous source that I had read was completely wrong.
After thinking about it, it would be more complicated than what I want to do now. Maybe if someone has the opportunity they can work on this and see what is necessary. A new driveshaft is all but guaranteed, and the shifter would be difficult to rig I imagine as all vehicles equipped with this transmission have column shifters.
I'll put in a post-'98 4R70W now and maybe get a 5R in the future.
TCCoA Gun Club
Palmguy is offline
post #6 of 6 (permalink) Old 09-21-2003, 07:43 PM
If the transmission will physically fit in the MN-12's, theoretically, the electronics would be easy to work out if you got something like a Baumannator TCS (if/when they support the 5R55. Who knows? Maybe with a wiring harness mod and some programming, maybe our stock EEC's could run the 5R55's (Probably not, though) I drove an '02 Explorer when I was on a buisiness trip in California, and liked the feel of the 5 speed auto... I wouldn't mind having one in my Cougar...
Best times:
