help me make a decision - TCCoA Forums
post #1 of 5 (permalink) Old 09-21-2003, 08:01 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
which should i do:
A. buy a used 8.8 rear end, swap in steeper gears, probably 3.55s, and stronger halfshafts
or
B. install a shift kit, tranny cooler and fresh mercon V
any advice is greatly appreciated. thanks.
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 5 (permalink) Old 09-21-2003, 09:00 PM
JustinH's Avatar
both.
You won't be happy with 3.55's.
3.73's or 4.10s would be more ideal.
I still have some FRPP 3.73 pumpkins for sale, check out the thread and pm me if you are intersted.
JH
JustinH is offline
post #3 of 5 (permalink) Old 09-21-2003, 09:09 PM
MaddMartigan's Avatar
If you have a 93 and an AOD I don't think you want to install Mercon V according to the tech articles. I could be wrong though.
MaddMartigan is offline
post #4 of 5 (permalink) Old 09-21-2003, 10:16 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
justin,
i have about $250 to spend so i have to choose one. i would be interested in your pumpkins but i dont think i have enough to get one. i plan to get a used rear end and rebuild it and swap in 3.73s.
MM - i think mercon V will work with an AOD.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 5 (permalink) Old 09-23-2003, 03:45 AM
Aaron_T's Avatar
I would say the shifkit.
You will still have some money left over (probably about 1/2), to go to whatever (or save). Plus the cooler will help your tranny (just flushing it will).
Having the firmer/hard shifts makes the car much more fun to drive IMO.
Ppl say gears will help a lot, and I do believe they should, but I didn't really notice anything as far as 1/4 mile with 4.10's. I may just need some more power to get good use out of them though.
If you found a good used rear-end right now, go for that, but if you can find one most of the time, then I say wait and do the shifkit/cooler.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
