Sloppy Shift Lever - TCCoA Forums
post #1 of 7 (permalink) Old 09-24-2003, 10:20 AM Thread Starter
Sloppy Shift Lever
How much slop does everyone have in their auto tranny shift lever?
I can move mine about 1/4 - 1/2 inch at the top and it just feels worn out.
My 97 Mark is tight as a drum with no slop what so ever.
I'm assuming I have some bushings wearing out since it’s getting progressively worse. I manually shift a lot, so that isn’t helping.
Am I looking at new bushing, or a whole new assembly?
69 F100 LWB w/460 Engine
post #2 of 7 (permalink) Old 09-24-2003, 10:26 AM
There should be a bracket that connects the shift lever shaft on the steering column to the shift cable. This tends to get loose - it has one attaching bolt that runs up into the shift lever shaft. This info is from the Panther platform. Mine worked loose at about 100k.
I've read about the bushings for this shaft wearing or failing in the column, but the bracket is the easiest thing to get to.
bill_s is offline
post #3 of 7 (permalink) Old 09-24-2003, 10:37 AM Thread Starter
MN-12's have the shift lever on the console, so I'm not sure what you're refering to.
What is the Panther platform? TC's, CV's and GMq's?
Thanks for the reply.
post #4 of 7 (permalink) Old 09-24-2003, 03:35 PM
3rd Gear Chirper
hotbird's Avatar
Mine moves like 2 inches side to side. I took it apart and it looks like the metal shaft passes thru a plate which it was tack-welded on to. I guess to fix it we have to pull the shifter out of the car and redo the failed weld.
hotbird is offline
post #5 of 7 (permalink) Old 09-28-2003, 11:15 PM
Sorry bout that. Panther brain.
bill_s is offline
post #6 of 7 (permalink) Old 09-29-2003, 02:49 AM
I have a lot of play in mine, found out I lost a bolt for the linkage bracket on the transmission.
The exhaust is in the way, so I'm waiting till the next time I have to pull it down to replace the bolt.
Chlorine is offline
post #7 of 7 (permalink) Old 09-29-2003, 07:10 AM
rustyul's Avatar
My shifter was tight before I removed the tranny. Now when you put it in drive, it doesn't quite hit the notch. If if push or pull it one way or another, it locks in place where it should. Sounds to me like my shifter cable bracket isn't quite in the exact same place that it was.
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
