Rear end gear ratio - TCCoA Forums
post #1 of 17 (permalink) Old 09-25-2003, 11:42 AM Thread Starter
Bigiron383's Avatar
Question Rear end gear ratio
I know ,I know, Jack it up turn the wheel and count the revolutions. Is there another way to find out the rear end gear ratio? How about if you have positraction, suregrip, ok, what do you (us) Ford guys call it?
Bigiron383 is offline
post #2 of 17 (permalink) Old 09-25-2003, 11:50 AM
JustinH's Avatar
Sure thats right in the tech articles.
Under the "AX" on the door jam sticker:
Conventional Lock Rear Axle Ratio
G H 2.26
B C 2.47
8 M 2.73
7 - 3.07
Y Z 3.08
4 D 3.42
F R 3.45
5(W5) E(XE) 3.27
6 W 3.73
2 K 3.55
A - 3.63
J - 3.85
JustinH is offline
post #3 of 17 (permalink) Old 09-25-2003, 12:35 PM
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
it's called trac-lok. or traction lock. from Ford.
chilipepprflea is offline
post #4 of 17 (permalink) Old 09-25-2003, 03:55 PM
jk69cat's Avatar
the correct ford term is limited slip. if you climb under neath your car, and look at the little steel tag bolted to the cover, the lower left number tells you what gear ratio and if it is a limited slip or not.
jk69cat is offline
post #5 of 17 (permalink) Old 09-25-2003, 04:24 PM
Johnny Bling Bling
93 lx's Avatar
or you could give me your VIN number and i can run it for you here at work. sometimes the tag is missing.
2009 Ford Flex Limited AWD
93 lx is offline
post #6 of 17 (permalink) Old 10-01-2003, 10:29 PM
Mine's missing. All I have is an old Ford oil change sticker on the driver door and a tire spec plate on the passenger side. Does Ford have a Web site I can get the ratio from online?
I come from a dusty place.
4point6r0x0rz is offline
post #7 of 17 (permalink) Old 10-02-2003, 12:20 AM
Silver95Bird's Avatar
So you have neither a sticker on the door or the jamb, and no tag on your pumpkin? Very odd. Sometimes the tags on the pumpkin get removed if the fluid is changed... depends on who does it. The door jamb sticker should be there, though ppl tend to paint over them if the car is repainted.
Silver95Bird is offline
post #8 of 17 (permalink) Old 10-03-2003, 02:50 AM
I don't have the door jam stickers and the previous owner did repaint the car so maybe that's what happened. I haven't checked the pumpkin yet. I'm guessing I have a 3.08 open diff. What are the chances I am wrong? I have a manual that explains the VIN(It's in my car right now). Can I get the correct diff specs from the manual?
post #9 of 17 (permalink) Old 10-03-2003, 03:14 AM
With no door jamb sticker, you have to rely on the diff tag.
most 95 have 3.08 open. however some, like my old 95, and 95LX among others, did have 95s equipped with 3.27 Trak-lok axles, they are out there.
post #10 of 17 (permalink) Old 10-03-2003, 11:29 AM
do a burnout, and it will tell you oneof two things. if one wheel spin, you either have 3.08s or you have 3.27 and your traclok needs rebuilding (advice not to be taken literally) -greg
glowing escape is offline
post #11 of 17 (permalink) Old 10-16-2003, 06:21 PM
I took the tag off yesterday. Here's what it says:
Code:
      S 5 1 0 F
3   0 8   8 8   4 L 0 2
How do I read that? I could guess that 3 08 on the left means a 3.08 ratio, but I don't want to assume. And the 88 seems to indicate an 8.8" diff. I have never seen another mn12 tag before so I have no comparison. Who knows for sure?
Thanks!
post #12 of 17 (permalink) Old 10-16-2003, 06:53 PM
jturmel's Avatar
Negative, "limited slip" is actually the generic term to apply to any of them.
The specific manufacturer names are as follows:
GM : Positraction
Ford : Traction-Lok
Chrysler : Sure Grip
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #13 of 17 (permalink) Old 10-16-2003, 07:38 PM
JustinH's Avatar
josh, you beat me to that one.
Ford calls it trac-loc.
JH
JustinH is offline
post #14 of 17 (permalink) Old 10-16-2003, 10:17 PM
5w30 Guzzler
JH
grrrr! dontchu mean I beat you to it?!
teasin!
post #15 of 17 (permalink) Old 10-16-2003, 11:53 PM
Send a message via AIM to willum
As for interpreting that axle tag, this picture may help... its from the Ford Service Manual.
That should answer your question...
Willum
willum is offline
post #16 of 17 (permalink) Old 10-17-2003, 12:05 AM
Thank you willum. That helps, but it brings up some questions. A build date of 4L02 doesn't make sense since there is no month beginning with 'L'. Is it a code for a real month like July or something? Also, is the 3 08 on my plate representing 3LO8 Traction Lok? Or is that saying '3LO8' Traction Lok is the code for 3.08 Traction Lok, which I don't have?
Thanks again!
post #17 of 17 (permalink) Old 10-17-2003, 12:16 AM
This is simply a guess here but since there are twelve months in the year and L is the 12th month, maybe it is december...
Then also if you consider the beginning letters of the 12 months
J F M A M J J A S O N D
A B C D E F G H I J K L
You can see why the first letter doesn't indicate the month because there are three that start with J and thus the reasoning for the abc way.
Just a guess now but i'm thinking that is correct. (the manual didn't explain this, at least not where I found the picture)
Willum
willum is offline
