Trans Wont Engage In Any Gear! - TCCoA Forums
post #1 of 3 (permalink) Old 09-29-2003, 03:59 PM Thread Starter
I just finished replacing the head gaskets because I was burning coolent. The white smoke on a hot day. The job started in early july. I just finished today and started the engine. Runs great, no smoke. Then when I tried to back it out of the dive way, the trans would not engage in any gear. The car was on jack stands in the front only, for four days. I has the shudder, trans cooler, mercon V. I am checking to see if I may have missed a connector, but I didnt take any trans connectors off. Please help!
Nick-H is offline
post #2 of 3 (permalink) Old 09-29-2003, 05:13 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Check the MLPS, but you should be able to get manual 2nd without anything hooked up, did you leak out any tranny fluid while the engine was out?
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #3 of 3 (permalink) Old 09-29-2003, 05:21 PM Thread Starter
No leaks, but I will check the sensor in a few Min. Thanks.
Nick-H is offline
